Resident Young Old Dude !
Truck weights
What does your truck weigh ?? Not what the Title says, but it's actual weight..
And with the weight, what is it, IE: short step, short wide, long box etc.. |
its all about the +6 inches
My 69 SWB GMC, fleet side small block Th350, coi8l rear, with alluminum wheels, intake, and headers came in at 3900 and some chainge. This was with no spare, but a small tool box and normal minimal junk. I have a pic of the ticket on another computer...but not this one.
Mine's a C/20 long fleetside, has 15" steel wagon wheels and 31's, weighs a little over 5000lbs with a full tank, spare, and hi-lift jack.
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck |
![]() Join Date: Jan 2000
71 shortbed/stepside. 250-6 with tremec 3550 5-speed. 3780lbs. with 200lb me and half tank of gas.
67-72 Addict!
I took this pic while sitting in my truck. 70' LWB, bed mat, 3/4 tank of gas and me(225)
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
20' Daredevil (Ret)
![]() Join Date: May 2003
K20, LWB, spare tire, 3 gas tanks but I can't recall how much fuel at the time - 5300#.
It was 11,300# before I unloaded the dirt...
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
3660 No spare alum wheels and thats As A SWB Back when my truck was a LWB It wieghed 3700 even.
Crap, gotta get down to 3,000. There goes the Dynamat.
'68 Short Step LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc |
Got Light Emitting Diode?
SB th350 LWB alluminum wheels no spare 3/4 tank and me(160 at the time, 190 now) 3900lbs
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's ![]() 1993 Cherokee work ride/weekend wheeler |
I knew they were around 4000 pounds, some of you have some great lower weight...
I weighed mine 14 or 15 years ago and it was a sort step, roll bar, front pre runner bar, 5 off road lights on top and 4 on the front bar, SmittyBuilt 3" double tube rear bumper, two High Lifts, ETC. and it was in the 4600 Lb. area. I was curious to get an idea of what it might be now that it's lowered with all of the pre-runner stuff and off road stuff gone. |
![]() Join Date: Feb 2000
Before the 454, with the 307 and me in the truck it was about 5,700.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
3/4 Tons are heavy My 85 wieghed over 6000 with a 454 it now wieghs 5800 with a small block But i carry around a ton of chains and a jack tools stuff like that.
Fabricate till you "puke"
My longhorn tips the scales right @ 4240, with about 1/2 tank fuel, & my 220 lb @ss.....the old truck is pretty stripped tho! I run no air or heat, minus front bumper, & inner fenders, Jazz plastic buckets, alum heads & intake on the SB chev, She is rolling on 1/2 ton suspension......& no door glass. The things we do for fun
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
hmm...
less than my 3800 lb Delta 88...
67 LWB fleet, 250 3 spd...
1983 Oldsmobile Delta 88 1967 Chevy C-10 stripper www.fcrperformance.com - wanna go...faster? talk to FCR. |
#15 |
Finally weighed my truck yesterday 10/23. It weighed 3900. SWB, iron head 350, tremec 5 spd, spare tire, small tool set, my 260lb a$$ and some misc. junk. I was surprised. I weighed my '98 ss camaro at the Motorplex and it was 3660lb. Not that much difference in imo.
GM 330HP/350, Magnuson 122HH, Tremec TKO 5spd |
#16 |
68LSS1, Why do you need to get down to 3000 lbs?
#17 |
turbo enthusiast
Hey, my '99 suburban weighs just over 8400lbs, does that count?
"But daddy, I didn't hit them all with a stick"...what my 6 year old tells me when I pick him up from school early for fighting ![]() |
#18 |
14.1 @ 96MPH
With my 230-240lb butt in the driver's seat, a half-tank of gas, trailer hitch, '99 Suburban bench, headers, Vortec heads, aluminum intake, 700R4 tranny, and new carpet, right about 4250lb.
I hope to cut that by a good amount with the LS1/4L60E...going from an iron block with iron heads and an aluminum intake to an aluminum block with aluminum heads and a composite intake should do that. ![]()
Project1970 - LS1 Swap Complete! ![]() |
