10-10-2004, 08:46 PM | #1 |
Proportioning Valve ?
I have a 71 Longhorn and was wondering if the p valve is the same as a 1/2 ton. My Horn is a 3/4 ton. Thanks in advance Tim.
10-10-2004, 09:39 PM | #2 |
SKINNY TIRES RULE!
Can't answer your question, but you might try checking the catalogs and seeing if they list different proportioning valves for the 1/2 and 3/4 tons.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
10-10-2004, 10:46 PM | #3 |
its all about the +6 inches
While a drum/drum vehicle IS different than a disc drum...I can say that i have removed the distribution valve (later replaced with the proportioning valve in 71) from a '70 CST/20 Longhorn, and installed it in a 69 1/2 ton GMC.
I would go out and look at them and compair things like line size, where each line goes to and from what port, and any other difference you could find. |
10-11-2004, 04:28 PM | #4 |
P Valve
Thanks. TTT
10-11-2004, 06:09 PM | #5 |
Tim, I have had some recent hands on with proportioning valves. I have found the exact same part on both the 1/2 ton and the 3/4 ton trucks. I have also found different proportion valves that I assume were aftermarket replacements. Mothertruckers recently quoted $79. new and $20. good used so you might contact them for a solution. Good luck---Huck
PS, finally got to install one of the SWB bedsides----fit perfect and lots of nice colors as I take the paint off----(:>) |
