Old 10-11-2004, 10:33 PM   #1
raphyel
I need pics of a 2.25" / 3" drop
I have 2.25" drop spindles on the front of my 63 c10 truck with stock height springs, with 3 " drop springs on the back. I was wondering if someone has used this setup and can send me a pic so I can see around where my project will sit when complete. I'd rather make any changes now that later. Any other pics 0f a dropped 60-66 c10 along with a description of the drop distances would be appreciated.
raphyel is offline   Reply With Quote
Old 10-11-2004, 11:33 PM   #2
kewlbear
I have a 64 with a 2/4 on mine and it sits pretty nice. little tuff getting rear tire out from under fender, cause those new coils have little stretch. Had to put p245 tires on it 255's rubbed. You prob need to check into the backspacing before you buy aset of wheels if you want some wider meat, wish I had. trim some off of wheel well inside lip might give you another inch. I also have the 72 rearend under it, not sure bout spec diff in the two. It was a direct bolt in but not sure if its same width, im asume it is.
64 Chevy pickup
tilt,pb, ps discs up front
350/TH350, 72 rearend
auto meter gauges
93 GMC extended cab
trailmaster conversion
kewlbear is offline   Reply With Quote
Old 10-19-2004, 01:50 AM   #3
Slammed66
Needs a Big Block
Slammed66's Avatar
Ill tade ya its a real bastard to change rear tire on this truck I can hardly wait tillI drop it some more , its at 6/10 but the back is on bags
1964 Short box
On dropmembers and billets
1962 Suburban family cruiser
1972 K10
Slammed66 is offline   Reply With Quote
