Old 10-14-2004, 04:15 PM   #1
neonlarry
neonlarry's Avatar
Radiator Overflow Bottles
I just recently picked up a couple of overflow bottles from some 80's G-Bodies at the local yard. Just installed them over the weekend I thought they came out looking pretty good.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 10-14-2004, 04:33 PM   #2
chickenwing
Lovin' Life in Miss.!
chickenwing's Avatar
Looks cool. Do they mount right next to the fender? And......whats a G body?
The truck... you hear that? No really, you did hear that?!!!
chickenwing is offline   Reply With Quote
Old 10-14-2004, 04:37 PM   #3
neonlarry
neonlarry's Avatar
Yes they mount next to the fender. G-Body: Monte Carlo, Regal etc.
Old 10-14-2004, 04:56 PM   #4
Hook'em
Hook'em's Avatar
Those look good. Couple questions:
Do you just run the radiator burp hose (or a longer hose from the same location) to the bottom of the overflow tank?
How is the overflow tank mounted? Looks like bolts through the wheel well.
Hook'em
Hook'em is offline   Reply With Quote
Old 10-14-2004, 05:47 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Just run the hose to the tank, get the proper rad cap, and you're set.
Travis, that is a pretty good fit there. Almost looks like it belongs there huh? Is it too close to the battery? It looks like it might hinder bettery removel a little.
Old 10-14-2004, 07:58 PM   #6
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
I have the same thing on mine,and it works great.It allows plenty of room for the battery to slide right in.And yeah looks like it came out with it on there.
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 10-14-2004, 08:08 PM   #7
Cethern
What was I thinking??
Cethern's Avatar
From the pic it looks like the hood hinge might hit...But seeing how more than one person has done this I guess not...I guess I'll have to hit the yard's around Denver.
72 K5 that needs lots of parts..
71 GMC 3/4 4x4 That doesn't need much which is a good thing I don't think I could aford another money pit...
Cethern is offline   Reply With Quote
Old 10-15-2004, 11:16 AM   #8
neonlarry
neonlarry's Avatar
If you get the tank in just the right place, there is plenty of room for the hood hinge, and to get the battery out.
Old 10-15-2004, 12:19 PM   #9
70c10
67-72 Addict!
70c10's Avatar
Thanks for posting neonlarry!. Do you just leave that overflow tank empty or should you put some antifreeze in it?.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 10-15-2004, 02:19 PM   #10
neonlarry
neonlarry's Avatar
I'll put antifreeze in but right now both are apart.
Old 03-03-2005, 03:34 AM   #11
53burb
53burb's Avatar
I just did this, and it fit like a glove. Thanks for the tip!!! I like it much better than the original.
53burb is offline   Reply With Quote
