10-16-2004, 09:28 PM | #1 |
Adding Power steering
What a great website!!! I'm new here so please be kind! Can anyone tell me what I need to do to add power steering to my 72 C10 with 6 cyl. 3-speed??
The truck has just 30k miles on it and is pretty tight, but at my advancing age and my growing laziness I am getting tired! Could the V-8 pump and box be used on this truck?? |
10-16-2004, 09:43 PM | #2 |
its all about the +6 inches
First and most important...welcome to the board. What part of the world do you call home?
As for your Q, the hard part is coming up with the brackets from what I understand. I would guess 9And that's all it is is a guess) that you could use the v-8 pump, as log as it fit in the brackets you get. The steering gear box will be the same from 1/2 ton to one ton regardless of engine. (Talkin 2 wheel drive...i have no clue on the 4X4 trucks) So you could get a power steering pump off any 69 - 72 and it'll bolt right up. You can also use the 73 - about 80 and it's a bolt on, but I am unsure of what arm you'd need. The later box will give you a variable rate steering which is cool. Again, welcome to the board, check it all out, tons of info of everything you wanted to know, everything you already forgot, and lots of ideas that'll make you turn wrenches more than intended. |
10-16-2004, 09:44 PM | #3 |
get the steering box off a later truck with hoses and bracket and swap it.
10-16-2004, 09:52 PM | #4 |
Thanks for the welcome! I'm from Sheboygan, Wi. I can probably come up with a set-up from a 71-72 4x4 with V-8 Auto. Chances are the price will be right(read that as REALLY cheap) so I was hoping for an easy exchange(Remember the Lazy part!)
10-16-2004, 09:54 PM | #5 |
The brackets will be useless for your engine...but good selling/trading material, esp if they are the correct brackets for a 69 - 72 engine, and not the later set up.
10-16-2004, 10:25 PM | #6 |
"Trucks with Class"
You need to get the bracket/pump/pulley set that will line up with your eng pulleys. There were several different setups. Your crank damper/pulley must have at least two grooves, with the proper spacing.
As an example: Here is a complete system (this system is already sold and it was a real hard to find 292). When all of this comes off the same engine, I can be sure everything lines up, otherwise I have to put individual pieces on a motor to insure they fit. You can piece it together, but as several guys on here will tell you, it often won't match your pulleys. I may have one pump w/brackets that will line up with one of the grooves on our 6 cyl engines. http://67-72chevytrucks.com/vboard/s...349#post985349 Last edited by PICKMUP; 10-16-2004 at 10:29 PM. |
10-16-2004, 10:19 PM | #7 |
Welcome from Cedarburg,WI!
69 Lwb C-10 402/700R4 70 Lwb C-10 250/3pd Wisc. |
10-16-2004, 10:32 PM | #8 |
Welcome! I finished this very project today on my 70 C10, 250 3 spd.You need a steering box from another truck, grab the coupling shaft too cause its diff size than one for a manual box. I got a pump & bracket from Pickmup(Frank), bracket fit fine but pump no pump. Went & got another used one locally & it worked. Had to use a double groove alternator pulley & water pump pulley. Both new belts as alt is moved in a little so old belt is too long. I used a 38 inch long belt for alt & 50 inch for P/S, normal belts for 70 C10 w/ps. Man, is it nice, especially in traffic or parking!!! Brian
10-17-2004, 12:58 AM | #9 |
Lovin' Life in Miss.!
Welcome from Northern California!!!!
The truck... you hear that? No really, you did hear that?!!! |
10-17-2004, 01:31 AM | #10 |
limpimp
Welcome aboard from Texas You have come to the right place to get all you questions answered about you truck. That is some pretty low miles for that truck, Less than a thousand a year.
John Hutchison Grapevine,Texas 68 1/2 t swb 68 Mustang 69 Jaguar 71 1/2 t swb 88 Supra CompTs6m 93 Escort GT 2005 Corolla XRS |
10-17-2004, 01:44 AM | #11 |
Ps
Welcome from Fall River (25 miles N. of Madison). The 4x4 box won't work. Sorry. Like PICKMUP said, you'll need a 6 cyl. pump. (It's the brackets that are different), and a 2WD box. The boxes are easy to find. I have 3 of them down here. There was a pump on the parts board earlier in the week, but is probably sold by now...............Zoomy
10-17-2004, 02:09 AM | #12 |
pump
Over in the parts section, PICKMUP has the pump you need. I probably have the pulley. Definitely have the box. NAPA has the lines. There you go ! Don't wait too long. 6 cylinder parts go fast on the board.
10-17-2004, 11:18 AM | #13 |
PROJECT 7DEUCE
Welcome to the board from rainy southern oregon..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
10-17-2004, 12:33 PM | #14 |
Welcome Aboard from the MidWest, Tulsa Oklahoma, I had one those set up on a 72 gmc 3/4 ton I once owned,Man the steering on that thing was smooth and effortless. :p
1961 BUICK LESABRE ** 1968 CHEVELLE SS 396 ** 1969 BUICK RIVIERA GS ** 1971 2 WHEEL DRIVE BLAZER ** 1971 4X4 BLAZER ** 1971 SHORTBED CHEYENNE FLEETSIDE ** 1971 SHORTBED 4X4 FLEETSIDE ** ...My Ebay |
10-17-2004, 12:32 PM | #15 |
You will need to know if your engine is a 250 or 292 because the brackets are different for each engine.
10-17-2004, 04:48 PM | #16 |
I may have learn to type faster to thank ya'll for the info and the welcome!
