Old 11-01-2004, 04:48 PM   #1
Goplay2
axle measurement
on a 1970 4x4 what is the axle measurement from inside brake drum
and what is the rear? help please
Goplay2 is offline   Reply With Quote
Old 11-01-2004, 08:26 PM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Are you talking WMS to WMS?
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 11-02-2004, 12:03 PM   #3
Goplay2
inside brake to inside brake,
Old 11-09-2004, 05:35 PM   #4
Goplay2
help
if someone could go measure there front and rear axle, it would really help.
Old 11-09-2004, 06:42 PM   #5
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
On mine from backing plate to backing plate, it's about 51 3/4". The axle in mine is the Eaton HO52, but mine's a 2wd. I don't know if it's different for a 4wd or not. I just know that 4wd's had leafs in the rear, mine has coils.
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 11-09-2004, 07:03 PM   #6
DennyB
Led Sled! Discs R 4 ME!
DennyB's Avatar
I do believe that '70 was the change over year and had two widths of rear axles installed. one matched the 69- and one matched the71+.
The earlier years were about 3/4" +- less.
"Never ride faster than your Angel can fly"
I.M.O.M,W,J&C
Patriot Guard Rider
DennyB is offline   Reply With Quote
Old 11-11-2004, 08:59 PM   #7
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Something I found: (not year specific)
GM Dana 60 front (single wheel) ...................69"
GM Dana 60 front (dual rear wheel) ..............77" ; +4" on each side vs single wheel
GM 14 Bolt rear FF (single wheel) ....................67"
GM 14 Bolt rear FF (dual wheel)........................63"
GM 14 Bolt rear SemiF (single wheel) ..............66"
GM Dana 44 Front (single wheel) ..............69"8-lug; 67" 6-lug
GM 10 bolt front (single wheel) ..............69" 8"lug; 67" 6-lug
GM 14 Bolt rear (Van single wheel) ...............70"
GM 10 & 12 bolt rear ..................... 65"
The rear axle that changed were the 2wd's when they went from 6 lug to 5 lug did not apply w/ 3/4 tons and 4wds.
Old 11-12-2004, 01:03 AM   #8
Goplay2
thanks, i look at that. i was told or read somewhere, that on the front d44 of a 1/2 that the spring perch were 32.5"?? i dont know if that right. the one i have is 1970 and i measure 31". if someone know that it might help too.
Old 11-14-2004, 07:41 PM   #9
RainFade
RainFade's Avatar
Would anyone have the distance between the center of the spring pads on the 67-72 rear leaf spring axles ?
THANKS
RainFade is offline   Reply With Quote
