Old 11-01-2004, 11:09 PM   #1
67ChevyC10Stepside
67ChevyC10Stepside's Avatar
guage question
i bought a cab off a 72 GMC and put it on my truck and am just getting things buttoned up. i switched to a internally regulated alternator which works like a champ and in the wiring i connected a lead to the wire that is supposed to go to my volt guage but nothing happens on the guage when the motor is running or what not it never moves...how do i track down the problem?
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon)
WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt.
67ChevyC10Stepside is offline   Reply With Quote
Old 11-02-2004, 01:11 AM   #2
67ChevyC10Stepside
ttt
Old 11-02-2004, 07:35 AM   #3
JimKshortstep4x4
Smile
A voltage gauge can hook up to ground and a positive wire anywhere or directly to the battery.
Is your volt meter an after market unit?
Jim
Old 11-02-2004, 12:41 PM   #4
67ChevyC10Stepside
it's the original 67-72 guage set......i think it works through the printed cicuit...can i just like hotwire it through the posts on the back?
Old 11-02-2004, 08:08 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
You have a stock VOLT guage?
Old 11-02-2004, 08:25 PM   #6
JimKshortstep4x4
Smile
It must be an ammeter. The ammeter circuit is completely separate from the alternator and picks up its signal from the resistance in the main cab feed wire. Assuming that your wiring is factory and intact, I would suggest checking the two little fuses that are on each side of the radiator in the wiring harness, (they look like little rubber footballs).
Don't wire the ammeter direct as you will fry it!
Jim
Old 11-02-2004, 08:23 PM   #7
67ChevyC10Stepside
im using the stock dash......whatever it is lol
Old 11-02-2004, 11:16 PM   #8
67ChevyC10Stepside
jesus.......dont anyone know what a stock guage is?
Old 11-03-2004, 12:29 AM   #9
Longhorn Man
did you look at JimKshortstep4x4's responce?
