Old 11-04-2004, 08:41 PM   #1
2low72
Frenched Antenna
I need to know what size antenna and where to get it from for this?Any help would be great!
2014 GMC Yukon XL (Wifey's)
2004 Chevy Silverado Crew Cab Z71
2low72 is offline   Reply With Quote
Old 11-04-2004, 09:03 PM   #2
GreyHoundSteve
hmm, the po of my truck did something similar to the passenger side of my truck but the pa he had installed isnt working but then again neither are the headlights or taillights so go figure. My painless harness is on its way and when i get it i'll have to pull that antena and when i do i'll check and see who makes it because it fits the hole perfectly and it looks just like the one in you pic.
GreyHoundSteve is offline   Reply With Quote
Old 11-04-2004, 09:35 PM   #3
longnlow72
longnlow72's Avatar
i think autoloc makes antenna's like that that retract, not sure though
72 Chevy lwb, cowl hood, shaved antenna, shaved bedrails, blazer tank, sidemarker fill, 1pc windows, flowmaster 40's, alpine deck, infinity 6x9's, infinity 4"ers, 2 jl audio 10w0's, grant wheel, keyless entry and alarm, more waiting to be done...
longnlow72 is offline   Reply With Quote
Old 11-04-2004, 09:40 PM   #4
djracer
djracer's Avatar
If you get the diameter of the tube and the diameter of the whole in the bottom. I should be able to help you. Do you want a manual or power antenna? I own a mobile car stereo shop!
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 11-04-2004, 09:53 PM   #5
2low72
djracer
the tube is an inch and a half across, and there is not a whole drilled through it yet.i'm looking for a power antenna. I was looking at some and they extend to far. are some power antenna's adjustable to how much they extend?
Old 11-04-2004, 09:56 PM   #6
2low72
Greyhoundsteve,
Is there a special bracket the po mounted it inside the cab or is it just hanging there
Old 11-04-2004, 11:30 PM   #7
djracer
djracer's Avatar
Some antenna's have a momentary switch so you can raise them as much or as little as you like! It does not have a hole in the bottom of the tube?
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 11-04-2004, 11:43 PM   #8
2low72
No hole. the po did'nt have a chance to installed an antenna so he didn't drill one. i'm going to do that when i get the antenna.
Old 11-04-2004, 11:48 PM   #9
GreyHoundSteve
I dunno, i can only see the top of it. I just bought the truck and havent even thought about the antena yet. I'll try to take a look at it and see if i can tell tomorrow.
Old 11-04-2004, 11:50 PM   #10
djracer
djracer's Avatar
I'll try to check a couple of my catalogs!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 11-04-2004, 11:57 PM   #11
2low72
Great thanks...
Old 11-05-2004, 12:12 PM   #12
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Auto parts stores should have an after market "power" that should fit. If the hole hasnt been drilled then you dont have to match anything, and with a 1-1/2 tube most gromets should have plenty of room.
sneakysnake is offline   Reply With Quote
Old 11-05-2004, 01:03 PM   #13
ale8oneboy
ale8oneboy's Avatar
I've seen this mod before. Don't you have to worry about water getting in and rusting out (if you use metal).
MEMBER OF THE BUCKET SEAT CLUB (REAL BUCKETS)
"Color Me Gone" - Two Lanes of Blacktop
ale8oneboy is offline   Reply With Quote
Old 11-05-2004, 01:16 PM   #14
2low72
yeah, i thought about that too. i am going to look into that. i might be able to make a drain hole right above the grommet(going to the inside of the truck) and attach a rubber hose to let it drain out the bottom of the cab. but i'm still thinking
