my gas saver
cleaning frame???
pulled my front end today. i heard a few guys using oven cleaner to clean the frame/suspension. will this eat up the bushings? i want to reuse most of this as it is only 1 1/2 years old. i will be replacing tie rod ends and such though, thanks again for the help, eric.
85' SWB, 4.3/TH350, getting ready for paint 84`SWB, 462ci./TH400, cowl hood, 15" billet spec., flows, blazer buckets/console, flat black 71`SWB, project ebay feedback |
Watch out for your cornhole !
![]() Join Date: Jun 2003
I've used it on chassis and engines with no "eating" issues on either.
I also use GUNK engine brite too, works good and cheap, but not near as aggresive as Oven Cleaner is. Make sure to thoroughly regrease any suspension stuff with lots of new grease to flush out any residual cleaner that may have worked it's way into the part.
![]() Join Date: Mar 2004
hey oven cleaner i've never heard of that one. cool idea.
ondrew |
my gas saver
tx, you are the man, i`m gonna frame up this truck so you`ll be hearing alot of ?`s from me, thanks again, eric.
Engine cleaner (gunk I think) and a borrowed pressure washer worked great for me.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. ![]() ![]() ![]() |
