Premium Level Member
Hatch handle question---removal question before I break something!
I am trying to remove the handle from a double wall hatch. I've got all visible retainers and screws off, but not sure where to go from there. The handle shaft(square) is inserted through the round piece w/spring inside the hatch. Its a bit rusty so I've been soaking with a lube/rust remover spray for a couple of days. I can't seem to get loose with minimal force. Am I missing something or should I just use the hammer(carefully) and try to tap out shaft?
I'd hate to break a good hatch and or handle mechanism so help is really needed. ![]() jakeslim |
![]() Join Date: Dec 2002
The way I got mine seperated was a small C clamp. One end one the shaft and the other end one the part with the spring. Sounds kind of funny but thats how I broke the inital seal. Also sanded the square shaft a little so when it came free it wouldn't bind again. Hope this helps
good idea. Now to go see if i have a c-clamp small enough.
thanks again, jakeslim
69 K5 CST stock- 350, 4speed ![]() 77 K5 - 383, auto, 6" lift, D60 front, 14b rear, 39" tsl's, |
