11-14-2004, 04:59 PM | #1 |
70+ ( Old Skool Club )
Sway Bar
I asked this question on the Burb board but so far no responses, so I'll try here.. I'm gonna take the the front sway bar from a 85 Burb I'm wrecking and want to know if the sway bar is bolted or riveted to the lower control arm.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
11-14-2004, 05:46 PM | #2 |
9/16 bolts
11-14-2004, 06:01 PM | #3 |
Watch out for your cornhole !
3/8 bolts.
11-14-2004, 06:14 PM | #4 |
Got Light Emitting Diode?
3/8 bolt with 9/16 head
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car) 1993 Cherokee work ride/weekend wheeler |
11-15-2004, 10:41 AM | #5 |
Thnaks
Thanks for the help guys, now I know its bolted and will drive the 20 miles to go get it myself. I don't have torches to cut rivets off.
11-15-2004, 03:08 PM | #6 |
The bar itself can be unbolted, rivets hold the bracket that goes between the bar and the frame.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
