Damn battery keeps going dead! Any ideas?
Any ideas of where I should look first? I haven't touched any wires lately, and it's just been doing this for maybe the past month.
Right turn Clyde
I thought you fixed it? Did you ever check the bulkhead connector where the engine bay and the fuse box meet?
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
Gentleman Jim Driver
Check for a constant draw. Get a 12v test light, remove your positive battery cable and put the test light between the cable and the battery + post. If the light is off, you have a battery that won't hold a charge or an intermittant load. If it lights, remove fuses until it goes out. The load is on the fuse that makes it go out. Start there.
If the light never goes out and all the fuses are out, the load is upstream of the fuse box. I had a draw like that on my 75, turned out to be the brand new alternator I had put it. I found it by unplugging the plug on the alternator.
Joe '75 GMC Gentleman Jim '84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter) '85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed |
#4 | |
charge the battery and then buy a test light therye like $4.99 at auto zone or any other auto parts store
so many trucks so little time!!! |
#6 | |
![]() Join Date: Apr 2004
If you have a mutimeter, use it. Just set it to read current (amps). It works like the test light but will tell you just how much of a current draw you have. If you have a amp for your stereo you should expect a little bit. Also, don’t forget to shut the door if the dome light is on. speaking of dome lights. I had a customer come in and have the dome light on . SHE didn’t drive it at night so she never saw that it was on..just a dead battery. She was happy that there was no charge nut a little embarrassed.
#8 | |
tim you have a tach in your truck? how is it wired? switched or constant? if it stays at 0 when ignition is turned off then its constant and you need to rewire it. I was having problems with my battery going dead and it was because of that, but it wouldnt always do it cause the ground wasnt the greatest and wouldnt always complete the circuit.
ok, I found the problem. I took every fuse out, and it still had a .3 amp draw...disconnect the alternator...0 amp draw! How would the alternator DRAW amps?!? Anyway, just sent the other half down to Kragens to get it warrantied. But it's odd...that alternator is only like a month old!
thats what happens when you get a bad load of parts for it like the diodes or you get someone who inadvertantly leaves some kind of short in it when rebuilding it. one time i had to go through three to get a good one all from the same rebuilder it was his garbage rebuild kits
Interesting though...I guess I should have sprung for the NEW alternators instead of the Reman ones...
#13 | |
DAMN, I love Big Blocks!
Either that, or stay a MILE away from Checker or Kragen. I buy my batteries, oil and filters there...nothing else. Everything else is either NAPA, a small local mom and pop place , or online.
Marc Bona Hobbs, New Mexico 1976 1/2 ton GMC High Sierra. 454 c.i.d./ TH400. *Soon to get a mild warming over.* 3.40 rear. ![]() |
#14 | |
#15 |
Under construction!
You wouldn't have to worry about a warranty if you purchased a quality alternator from GM or Powermaster. Like Mike always says....."You get what you pay for."
2001 Silverado bagged on 22's. *Sold* |
#16 |
I always ask "where was it rebuilt at"
If mExico is the answer I go elsewhere. |
