11-14-2004, 07:04 PM | #1 |
Tank Help Needed!
I notched the crossmember for tank clearance. But the filler neck hits the crossmember where bed bolts to the frame. I have had ideas of shortening the neck a little but am not sure. I also thought of heating and bending the filler neck on the tank. Do you think Heating it would be ok? Any Ideas? Here's a picture of just what im talking about. The black marks are where the edges of the crossmember are when mounted. Any experiences, tips, ideas, etc, would be appreciated.
-Ben
72 Chevy lwb, cowl hood, shaved antenna, shaved bedrails, blazer tank, sidemarker fill, 1pc windows, flowmaster 40's, alpine deck, infinity 6x9's, infinity 4"ers, 2 jl audio 10w0's, grant wheel, keyless entry and alarm, more waiting to be done... |
11-14-2004, 08:26 PM | #2 |
Life, Be In It.....
Is it possible to un bolt it and turn it upside down? Would that change the angel of the filler neck?
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows" http://67-72chevytrucks.com/vboard/s...d.php?t=200082 |
11-14-2004, 08:58 PM | #3 |
Semi-Senior Member
can you shift the tank forwards or backwards a little? We did and used 1 1/4 filler hose, available from Dayco,(from your favorite auto parts store) and flexed it around it.
'68 50th Anniversery LWB Custom Fleetside, '77 305 v-8, turbo 350, factory speed alert (still works), '71 drivetrain w/front discs. Some call it ugly yellow, others call it Ochre '83 Jeep CJ-7, <80,000 miles, original owner '04 Chevy Suburban, 4x4, 2500, 6.0 ltr, Predator Diablo programmer '95 GMC K1500 Extended cab |
11-14-2004, 09:40 PM | #4 |
unfortunatly thats all the way up, all the way back was dead center into the crossmember, u were able to stretch the 1 1/4" hose over the neck? ill have to try that
11-15-2004, 12:14 AM | #5 |
Semi-Senior Member
we had the plastic tank, it may be different from yours. I'm also operating on a 9 month ago memory.
11-15-2004, 02:44 PM | #6 |
Semi-Senior Member
Here's some more thoughts.....most guys take that crossmember completely out. We didn't because we used a plastic board that I felt needed the crossmember there. I made a member by taking a thin piece of steel and welded smaller legs at the holes to make more room. I might have some pics if you're interested.
11-15-2004, 03:02 PM | #7 |
It's a catastrophic success.
Cut it back, solder a copper 90' or '45 depending on where you are heading with it. HVAC or a good plumbing shop carries the bigger sizes
11-15-2004, 06:14 PM | #8 |
Does any one have thoughts about taking it to a radaitor<sp> shop & have them relocate the neck to the rear of the tank?
