Old 11-19-2004, 11:16 AM   #1
8t5Silverado
Mudslides 'r my specialty
8t5Silverado's Avatar
Replacing Emergency Brake Cables
My local auto parts store only carries the rear cables (left and right).
1) Is that all I need to get my emergency brake working again?
2) Do I need the front as well?
3) If I do, is the front cable a dealer-only part?
I am going to attempt to do these this weekend, so thanks for your help.
Always on the lookout for old cars and parts...(20s, 30s, 40s, 50s, 60s, etc.)
http://www.cardomain.com/memberpage/500339
8t5Silverado is offline   Reply With Quote
Old 11-19-2004, 11:21 AM   #2
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
1) Not really sure, depends what's wrong with them. It could just be an adjustment...
2) Same deal. If its binding up, then replace it too. Check it when the rears are disconnected and you will know right away. Be under the car (with gloves on) have someone in the car work the pedal back and forth and see if the cable is moving freely.
3) I'm pretty sure you can get the front cable at Napa. I bought mine from my local AC Delco dealer...
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed
ElGracho is offline   Reply With Quote
Old 11-19-2004, 02:02 PM   #3
8t5Silverado
I already tried adjusting it.
There is too much cable at the pedal (loose pedal) but the rear is super tight, almost locked up, so I had to back it off.
Old 11-20-2004, 11:28 AM   #4
8t5Silverado
Anyone? I want to try and fix it this weekend (while I have help), so your advice would be very appreciated.
Old 11-21-2004, 10:04 AM   #5
82 Silverado 4X
Genuine Chevrolet
82 Silverado 4X's Avatar
It sounds like your front cable might be hanging up. Since the front cable is where the adjustment is, replacing it makes adjusting them much easier. I got the rear cables at Car Quest and the front cable from Napa when I replaced mine 2 yrs ago. I use the E-Brake every time I park the truck to keep it loose and even with the snow, salt, mud and dirt it continues to work perfectly.
George
82 Silverado LWB 4x4 350 SM465 NP208
77 Chevrolet Blazer Chalet 400 TH350 NP203
82 Silverado 4X is offline   Reply With Quote
Old 11-22-2004, 03:49 PM   #6
8t5Silverado
I will have to try another parts store. Thanks.
