11-19-2004, 09:06 PM | #1 |
The oddest Todd around
1 piece driveshaft conversion
Ok, so I know I can replace my 2 piece driveshaft for a one piece driveshaft in my long bed truck. (This would definitely fix my u-joints / carrier bearing problem)
What I need to know is what kind of conversions I need to do to get it to work. Like how long does the driveshaft need to be? I know that I have the short nose turbo 350 transmission (I've checked into this before when checking into a 700r4 conversion). Also, do I need to remove or cut the crossmember that the carrier bearing is in the middle of? Basically, what kind of problems am I going to run into, and how do I get around them? Todd |
11-19-2004, 09:10 PM | #2 |
Chevy Nuttttt
Take a mesurment from the back of the trans to the inside cup on the pinion. that will give you your overall lenth. subtract 2" for slip and that should take care of the shaft then if stuff will get in the way, remove it.
67' Chev swb step side 69' SS elky 03' Chev ext cab 4X4 hey who lernt me to spell is there anything else? |
11-19-2004, 09:13 PM | #3 |
Young truck fanatic
If anyone has done this conversion please respond, i am also very interested in this.
'67 Chevy Longstep 2wd 350 w/4spd manual Muncie M21. My first project. **Proud to be Valley Trash** |
11-19-2004, 09:34 PM | #4 |
I'm worried that if I remove that crossmember it will cause problems.
11-19-2004, 09:38 PM | #5 |
Chevy Nuttttt
you shouldn't have to rem the crosmember just the hanger for the carior bearing. at worst notch and plate it
11-20-2004, 04:39 AM | #6 |
This is an easy conversion. I had mine made at Truck Pro (they work on 18 wheelers) for about $185.00 including solid u-joints. Only thing I had to do was take a sawzall and cut the bottom of the carrier bearing crossmember for clearance. Good luck and keep on truckin'.......Jerry
'68 c-10 long wheelbase fleetside, been in family since new, originally 250 3 speed Now (389) 350 .060 over 3.75 stroke,Edelbrock Performer RPM 70cc heads and Intake 600 cfm Edelbrock,Small Comp Cams retro-roller cam and roller rockers,9:1 cr, headers, HEI,Old Air a/c, 72 power disc brakes w/stainless lines, 3.42 gear,T-56 6-speed, original paint(what's left of it). Dakota Digital Dash |
11-20-2004, 07:50 AM | #7 |
blood type; Retumbo
I would stay with the 2 piece. there is nothing wrong with this system. in my opinion it works better due to shorter shafts are less likely to be out of balance & no mods are needed.
Todd
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
11-20-2004, 08:26 AM | #8 |
jlmtrout, do you remember how long the driveshaft had to be? This is my daily driver so I can't have down time on it.
11-20-2004, 08:34 AM | #9 |
its all about the +6 inches
Todd...it'll be over 6 foot long, so you need to call your driveline shops and see if they will even consider doing it.
Most will not. Nothing wrong with the 2 pc, I've seen a daily driver that was doing 12's on the weekends running a 2 pc. Never a problem. if yours keeps falling apart, there is something else wrong. |
11-20-2004, 08:45 AM | #10 |
I believe that somebody said before that Texas Gear and Axle here in Fort Worth would do it.
11-20-2004, 08:56 AM | #11 |
I had mine done by CT Driveshaft here in Houston. I called them, they told me where to measure from, I took them the old driveshaft so they could take the yokes off of it, and in about two hours I had a new one piece. By the way, it was on a 72 ssuburban. Call a local driveshaft shop, they should be able to help.
Good luck.
My Suburban Project 72 Suburban 68 SWB 57 Belair 55 Cameo 06 Chevy 1/2 ton crew 09 Suburban |
11-20-2004, 08:54 AM | #12 |
Watch out for your cornhole !
Nope, it's Ft Worth Gear and Axle.
Call them or go in. They'll tell you exactly how they want it measuerd so they can build it right. I use them for all of my driveshaft work. Top notch operation. Less than 10 miles from your house too.
11-20-2004, 08:58 AM | #13 |
Tx Firefighter, do you remember how the prices run at Ft Worth Gear and Axle?
11-20-2004, 09:07 AM | #14 |
I paid 200 for a whole new driveshaft with a new yoke and u-joints included.
The yoke was 60 of that price.
11-20-2004, 09:33 AM | #15 |
And I guess I'm definitely going to have to cut the crossmember. I didn't think that sawzall was going to get as much work as it has when I bought it almost 2 years ago.
11-20-2004, 01:28 PM | #16 |
Senior Moment
I just did this on my sons truck a Lowered long bed. I taked to my local driveline shop 1st, They told me where to measure. Turned out to be 71 and 3/4 inch . We removed the center support bracket and it fit perfect. No vibrations or shakes at all. New yoke included ran $275. Thing are more $$$$ here in Ca . It does work, Good luck
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
11-20-2004, 02:00 PM | #17 |
Another way to fix your "u-joints/carrier bearing problems" is to use a two piece shaft with a slip joint on the rear shaft. This system is used on late model trucks and is a lot better, no long shaft to worry about.
Gene "Big Dog" |
11-20-2004, 01:58 PM | #18 |
If the length is a problem why did gm put one piece on later long beds .I have one from 1980 gmc and I haven't checked for fit but it looks longer then the two piece.
11-20-2004, 02:01 PM | #19 |
Your 80 model would have had the 9 inch tailshaft transmission.
I've always suspected that's why they went from 6 to 9 inch tailshaft transmissions in the next series of trucks, so they could run 1 piece shafts in long beds. Like I said, I suspect that's why, I have no proof of it though.
11-20-2004, 02:02 PM | #20 |
which brings up another question.
What are the pro's and con's of a 1 piece driveshaft? |
11-20-2004, 02:10 PM | #21 |
As long as it's built properly, there are no cons to a 1 piece driveshaft.
Back in the day, they had trouble making a driveshaft long enough that wouldn't whip under high speeds. Now, if needed, they can even make them out of exotic stuff sometimes like fiberglass or other composities. A good driveshaft shop (like FW Gear and Axle that I recomended) will have no problems making you a nice steel 1 piece shaft that will run true and smooth. They also use Spicer u-joints, which in my opinion are top notch. There are plenty of downsides to a multi-piece driveshaft. That carrier bearing and extra u-joint mainly.
11-21-2004, 05:14 PM | #22 |
my dad put a one piece in a LWB back in the late 80's -it was a ford drive shaft he found that was long enough and he just got the special u-joints to adapt ford/chevy parts and it worked fine
He did have to cut the lower part out of the x-member since he didn't want to lower the truck though
1972 LWB 4x4 1970 LWB 2wd 1971 chevelle 1972 datsun PL-521/nissan |
12-25-2004, 05:39 AM | #23 |
71 rustless in texas
I just put this in another thread. I got a 4" aluminum driveshaft from the junkyard last weekend. They also had a carbon fiber one there. I paid $50.00 for it. It was 5/8" shorter than the 2 piece. The aluminum one was off a 98 1500 and the carbon fiber one was off a 2002 Yukon. The only thing I had to do was put odd ball u-joints (3 1/4" X 3 3/4") that I got from a driveshaft shop. They cost about $30.00. I trimmed the opening of the crossmember 1" all the way around and welded a strap on the bottom for support. I'm having a tubular hoop made and welded in next month, which will eliminate any clearance problems. Luckly I know some racers who have all the stuff to do that for me.
