11-21-2004, 10:07 AM | #1 |
test run engine witout power steering connected?
Sorry for all the questions lately. I'm getting close to firing this thing up and am outside the realm of my experience.
for the sake of a test engine run, can I get away without hooking up the power steering pump? That is, avoid installing the power steering gear, lines, and fluid. Or will this damage the pump? In truth, I'm trying to avoid buying the power steering gear until I'm ready for it. Thanks for all the info! --Ryan |
11-21-2004, 10:11 AM | #2 |
Watch out for your cornhole !
Leave the belt off of the p/s pump. You don't want to run it dry of fluid.
11-21-2004, 08:46 PM | #3 |
How can you route the belt to avoid the ps pump - I can't see a route... I guess the only thing I really need running is the water pump?
11-21-2004, 09:28 PM | #4 |
GM ONLY BABY!!!
What is a power steering gear? There should be 1 belt that drives the power steering pump. Just don't put the belt on the power steering pump.
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
11-21-2004, 11:31 PM | #5 | |
Next project: 1970 K10
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
11-21-2004, 11:41 PM | #6 |
Steering gear is short for steering gearbox.
11-22-2004, 04:00 PM | #7 |
GM ONLY BABY!!!
Oh, you meant the gearbox.
11-22-2004, 04:58 PM | #8 |
In my case I have just the one belt that drives everything, thus I cannot leave out the power steering belt. Maybe I just have to wait for the gear box...
11-22-2004, 05:04 PM | #9 |
I've never seen a factory setup that used only 1 belt and had powersteering.
11-22-2004, 06:32 PM | #10 |
Chevy Nuttttt
as long there is fluid in the syst it would be fine
67' Chev swb step side 69' SS elky 03' Chev ext cab 4X4 hey who lernt me to spell is there anything else? |
11-22-2004, 06:38 PM | #11 |
what year is your truck do you have a serpentine system and if so just wait
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
11-22-2004, 07:15 PM | #12 |
Still drivin' a Rat Rod
You could slip a hose over each end of the steering hoses,and clamp it tight,just to fire it off.I wouldn't run it a long time like this.
At least it will circulate the fluid,and not burn up the pump.
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website |
11-23-2004, 11:03 PM | #13 |
it's an 04 crate motor with serpentine system. Brainchild's idea may work for a quick test, if I can clamp it down tight enough.
11-23-2004, 11:10 PM | #14 |
68cst_ss490
when i broke my small block in on the stand i ran the pump with fluid in it. put the pressure hose in a jug of flluid along with areturn hose to the pump and run it. doesnt build much pressure or heat doin it this way. plu sits a good way to flush out your pump
Dean edmonton,canada a winter wonderland 2005 Chevrolet Avalanche LT cold air intake, performance exhaust, Comp cams cam, jba shorty ceramic headers. http://www.cardomain.com/ride/3090973 |
11-24-2004, 09:33 AM | #15 |
couldn't I just loop a hose from the pressure line around to the return line? That way there'd be no pressure built up but it would just recirculate the fluid to keep from heating up, right?
