11-25-2004, 08:21 PM | #1 |
Navel Inspector
Replacing gas tank.
I can't seem to get the new one in. I can get into the filler hole but then the passenger side is stuck in front of the seatbelt and on a bracket on the floor board. Anyone have any ideas there? Looks like I'll be needing cab corners too someday soon. I'd like to replace every and all weatherstripping(if I decide to keep the cab) before any bodywork will be done.
Well, I just found a little info about what I might be doing wrong. I had the grommet in first and I read a post that says to install the tank first then thr grommet. I'll be trying that next.
1948 Chevy Aerosedan GONE! I think. 1984 Cadillac Fleetwood Brougham Coupe WANTED 1967 IMPALA 1967 CST C10 Long Bed with a 283 Last edited by Warbones; 11-25-2004 at 08:30 PM. |
11-25-2004, 09:16 PM | #2 |
I always put the gromet on then silicone spray it a bunch then shove it through the fill hole. I think I usally keep passenger end high when shoving tank through.
11-25-2004, 10:00 PM | #3 |
I install tanks like Solver does only I use hand soap (without the grit in it). This method works very well. Putting the grommet in afterwards is a job!
Jim |
11-26-2004, 11:45 AM | #4 |
Where's my beer?
I put mine it with the grommet slid down the filler neck and then slid it up into place, then took a screwdriver and worked it into position. I also put some WD40 on it to help it slide into place. Tank went right in without the grommet to fight.
