Old 11-26-2004, 08:18 PM   #1
GMCjunkie
Dude...I'm a CHICK
GMCjunkie's Avatar
Help Please, My Burb is protesting...
I just dont think she appreciated having to get up and go to work today. I admit shes been runnin a little rough lately, and the weather has been getting colder. I know shes due for new plugs etc. But, This morning she started hard, and as I was driving, outta no where, she died, I pumped the gas and she came back to life, died again this time I put er in N and restarted , she started strong, no struggling. I was a little low on fuel, but not sucking fumes. I got her to the Chevron, put about 1/2 tank in her and she ran fine all the way to work, (14 mi). AFTER work, I let er idle and warm up, shes still runnin a little rough, but runnin. I start home, get about half way, she dies, (no warning, no sputtering or anything, just ....off) Then just as I throw her in N to restart, she starts up on her own and BACKFIRES, 3 times. Prolly scared everyone with in a country mile chitless, myself included.
Fuel filter?? Plugs?? Could the starting hard in the mornings be the carb?? or choke?? Im pretty sure I need a new choke spring, had a guy order one for me but it was the wrong one, (mine was under the one he ordered was over or vice versa) Where can I get a NEW correct spring?? What could the problem be?? Shes NEVER back fired before.
Thanks for the help.
junk
"The unexamined life is not worth living" -Socrates
'71 GMC Suburban 4x4
GMCjunkie is offline   Reply With Quote
Old 11-26-2004, 08:25 PM   #2
Sweet72
Sweet72's Avatar
Ever replaced the timing chain? Could be a fuel filter or pump getting ready to go. sounds like fuel mixture is lean or timing is off.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 11-26-2004, 08:30 PM   #3
GMCjunkie
Dude...I'm a CHICK
GMCjunkie's Avatar
Chain was replaced about 4 years ago, guess she could be outta timing, not sure how the fuel would be "lean".
Old 11-26-2004, 08:39 PM   #4
JimKshortstep4x4
Smile
Do you have a points type distributor or have you converted to HEI? What you describe sounds like a points distributor problem when the gap closes up from wear.
I would suspect the ignition more than fuel since it backfires when running down the road. If you have HEI a module or pickup coil can cause similar
problems.
Jim
Old 11-26-2004, 08:36 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Jodie, didn't they replace the engine 2 years ago?
Do you have points or HEI distributor?
Old 11-26-2004, 08:40 PM   #6
GMCjunkie
Dude...I'm a CHICK
GMCjunkie's Avatar
Andrew, engine was replaced less than 2 years ago, I have HEI. Now would be a good time to come over for dinner
Old 11-26-2004, 09:17 PM   #7
Longhorn Man
Hmmm, whats for dinner?
More importantly, whats for breakfast? <insert slutty smiley>
Old 11-26-2004, 09:36 PM   #8
Wootdog
Wootdog's Avatar
Trash in the tank
All I can tell you is what I have observed. I had trash in my fuel line that caused the vehicle not to run. After I flushed the tank and installed a new fuel filter it ran ok. Kerry
1967 C10
Got it back after three years
Boy I sure missed Peppy
1969 Chevelle
1990 IROC Z Convertible
2002 Silverado LT
Wootdog is offline   Reply With Quote
Old 11-26-2004, 08:42 PM   #9
Wootdog
Wootdog's Avatar
Fuel Filter?
Jodie,
If you like most people tend to run the vehicle low on gas, IE below a quarter of a tank, alot of the time you might have picked up some trash in the fuel filter. I had that happen with a F*rd I used to own. Had to drain all the fuel out of the tank, clean it out, and change the fuel filter. Never had a problem again. Or you might have just got some bad gas. My two cents, Kerry
1967 C10
1969 Chevelle
2002 Silverado LT
Old 11-26-2004, 09:05 PM   #10
CG
BlahBlahBlah
this happened to me recently in my burb. when i did get it to start the exhaust was very black. i popped open the carb(stock quadrajet) and blew it all out. i didnt see anything that looked bad. i put it back together and tossed in a new filter and its ran fine ever since.
Old 11-26-2004, 09:02 PM   #11
GMCjunkie
Dude...I'm a CHICK
GMCjunkie's Avatar
Something else I forgot to mention. A couple times in the last 2 weeks or so, my truck would "diesel" when I went to shut it off. Im going to pull the filter and check it in the morning.
Old 11-26-2004, 09:15 PM   #12
Longhorn Man
This makes me think the trouble is in your distributor/plugs/wires even more.
As far as running low on fuel and suckin up crap, I have never believed these stories. I have never seen it happen, and I have run out of fuel many, MANY times when my guage wasn't working. Also, it just doesn't make any sence. Yout fuel is sucked from the bottom of the tank. Regardless of how much fuel is in there, it is sucked from an inch or so from the floor of the tank. 99% of the junk that gets in your tank...including water...goes straight to the bottom. So it'll either get sucked up asap, or it'll just sit there.
I'm not trying to call you a liar, just saying it makes no sence at all.
Old 11-26-2004, 09:35 PM   #13
GMCjunkie
Dude...I'm a CHICK
GMCjunkie's Avatar
OK... something else just came to mind. When my truck is cold, when I start er up, she dont idle down easily, even after shes warmed up, also the brakes feel "robbed", not like needs pads, but just ,,,,hmmmm. Not quite all there... is this making any sense .. (Atleaste I havent had to use the word, "thingie" yet)
Kerry, thank you, gonna check that filter just for "funsies"
CG, mine also has a Qjet, havent noticed black or dark smoke tho.
Andrew, oddly enough, your reasoning make sense, lol. Will still check it tho.
Gonna change the plugs Sunday, wires should be fine, unless theres something obvious, like a burnt one or something. Will try to check these before work in the morning.
Dinner?? You name it darlin....
Breakfast??? Whats breakfast?? Must be that fruit and yogurt that I cram down my throat on my 10 min break...
Old 11-27-2004, 10:36 AM   #14
tom hand
CCRider
tom hand's Avatar
Sounds like a vacuum leak....could be the brake booster itself
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 11-27-2004, 10:56 AM   #15
64fleetside
Your automatic choke is not working correctly, its either not correctly set or inop. When engine is cold(sat overnight), a tap of the accelerator should close the choke blade. After startup, choke plate should crack open a small amount to allow engine to run, then the blade continues to open slowly as the engine warms up. Start with a new spring & then set the choke after engine has been sitting overnight. A manual may help w/setting procedure, if I was closer I would come do it. Brian
64fleetside is offline   Reply With Quote
Old 11-27-2004, 11:08 AM   #16
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
I THINK IT'S A PROBLEM WITH YOUR "LUV TROLL"
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 11-27-2004, 10:02 PM   #17
GMCjunkie
Dude...I'm a CHICK
GMCjunkie's Avatar
Tom, how exactly would I check to see if its bad?? Thanks.
Brian, Thanks so much!! I believe you would come help if you could, thanks for that break down, that did help me understand that crazy little carb thingie a little better
LUV2... My love troll can kick your love trolls @ss...
Chris, do you HAVE to have a timming light to check the timming?? Is there any other way??
Thanks so much everyone, I appreciate ALL your comments and suggestions. Hopefully it wont be raining tomorrow and I can get something accomplished.
Take care
junk
Old 11-28-2004, 10:22 AM   #18
tom hand
CCRider
tom hand's Avatar
The easist way to test the booster is to get a small pair of vise grips and crimp the vacuum hose shut....then test to see if your other problems disappear...try to limit your tests to the driveway...it would be VERY hard to stop if you drove it. And since you have several problems that have occured at once...hard starting,rough running,dieing,deseling,backfiring,weak brakes....I would be willing to bet your problem is a large vacuum leak....ie brake booster or the hose from the booster...carb loose or bad gasket....intake manifold gasket leak...Good Luck
Olive Branch MS
Old 11-26-2004, 09:39 PM   #19
TugOwar
I am confused, which isn't unusual, but still...
The timing chain was replaced 4 years ago but the engine was swapped out 2 years ago. So ummm, the engine that is in the burb now has a 4 year old timing chain in it?
Anyway, sounds like a timing/firing issue, at least for the backfiring. Trash in the carb may make one spit, sputter and die but I don't see trash making one backfire.
Noone been tinkerin under the hood have they? Years ago at work this guy goes out after work, gets in his 72 C10 and it's running like crap, spittin, backfiring. Was running fine that morning. Turns out some d***head decided it would be funny to swap a couple of plug wires around.
TugOwar is offline   Reply With Quote
Old 11-26-2004, 09:46 PM   #20
GMCjunkie
Dude...I'm a CHICK
GMCjunkie's Avatar
Tugowar... "YOURE" confused?? ... "IM" confused. When the engine is changed, would the timming chain be an automatic change?? If so, then it was changed about 2 years ago.
I dont "think" anyone has messed with my truck, but, I will check that too.
Thanks for your input
Old 11-26-2004, 09:56 PM   #21
CG
BlahBlahBlah
brake vacuum comes off the back of the carb...arent these oddball problems fun ?
Old 11-26-2004, 09:59 PM   #22
GMCjunkie
Dude...I'm a CHICK
GMCjunkie's Avatar
If theres anything "weird" odd" or "never happens" its gonna happen with my poor Burb
Thanks again, I suspected a vacum leak, will also check that tomorrow when I have some daylight.
Old 11-26-2004, 11:37 PM   #23
silvertonguedevil
silvertonguedevil's Avatar
I would probably say it's either a vacuum leak of some sort or a timing issue. Isn't it frustrating to not be able to have everyone show up with beer and fix the dern thing
-Greg
My Chevy trucks, past and present:
1962 C10 SB Fleetside
1964 C10 LB Fleetside BBW
1966 C10 SB Fleetside
1966 C10 SB Fleetside BBW
1968 C10 SB Fleetside
1971 C10 LB Fleetside
1971 C10 SB Fleetside
1972 C10 SB Fleetside Cheyenne
1972 C10 SB Fleetside Cheyenne Super
1972 C10 LB Fleetside Cheyenne Super
1974 C20 Cheyenne
1979 K5 Blazer Cheyenne
1982 K10 SB Fleetside Custom Deluxe
1982 K10 SB Fleetside Scottsdale
1986 C10 SB Fleetside Silverado
2008 Silverado 1500 4x4
silvertonguedevil is offline   Reply With Quote
Old 11-26-2004, 11:44 PM   #24
Dean23
68cst_ss490
Dean23's Avatar
by chance it could be a distributor module on it s way out.Ive seen them do some weird things.. timing shouldnt change unless you change it, and the chain shouldntbe stretched too bad in 2 years.try the basics fule filter, air filter, plugs
Dean
edmonton,canada
a winter wonderland
2005 Chevrolet Avalanche LT
cold air intake, performance exhaust, Comp cams cam, jba shorty ceramic headers.
http://www.cardomain.com/ride/3090973
Dean23 is offline   Reply With Quote
Old 11-27-2004, 03:44 AM   #25
Solver
Solver's Avatar
I'll try one also
Sounds to me like the power piston in the carb is hanging up.
Dumps to much fuel and floods out
also with the extra fuel it won't idle well
also with the extra fuel in the mainfold and cylinders she will diesel and maybe even backfire.
Just my guess.
  • 1972 Cheyenne Super 20 LWB-Blue
  • 1972 Cheyenne Super 10 LWB-Black
  • 1972 Cheyenne Super 10 LWB-Red
  • 1972 Cheyenne Super 10 LWB-green
  • 1972 GMC 4x4 LWB-White
  • 1971 Cheyenne 10 LWB-Ochre
  • 1971 Cheyenne 20 Longhorn-Copper
  • 1971 Cheyenne 20 Longhorn-Black
  • 1969 Custom 10 LWB-lt blue
  • 1968 GMC 3/4 ton-green
  • 1968 1/2 ton swb stepside-silver
  • 1967 Chevrolet CST 10 LWB-green
  • 1967 Chevrolet custom 20 LWB-Maroon
Solver is offline   Reply With Quote
