Old 11-27-2004, 09:16 PM   #1
kwmech
engine placement
Have a 69 GMC 1 ton. Soon to pull the 350 out and go to a 400sb. Also going to put TBI on it with the serpentine belt set-up. I think the serp set up pushes the fan forward about 1 to 1.5'' forward. My thoughts are to use the big block towers which will allow the use of the heavier duty motor mount. Will this put the engine back for the fan placement?
Old 11-27-2004, 10:03 PM   #2
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
i thought that sb and bb mounts were the same, except for a dip in them for the manafolds??? if that were true you could use bb mounts on a small block
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 11-27-2004, 10:38 PM   #3
breeh
Recovering 67-72 Addict
breeh's Avatar
I agree with 68w/sbc406. I am not sure that changing the motor towers is going to change engine placement. the solution might be as simple as not running a fan spacer to gain back fan depth in the shroud. If it still pushes the fan too deep you might be able to run a big block shroud which would also allow the use of a bigger fan blade.
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt.
"Friends call me cruzer cuz I like fast cars and fast women"
breeh is offline   Reply With Quote
Old 11-27-2004, 10:50 PM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
set it on 6 cylinder stands in the rear holes.
Problem solved....
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 11-27-2004, 11:46 PM   #5
kwmech
The set-up I have with the serp belt is a fan clutch. I like the idea of the BB shroud, that may work out just right--won't have to move the trans then.
