Old 11-27-2004, 10:26 PM   #1
Mint68
Mint68's Avatar
DANA 44 Front axle problem
Does anyone know if a dana 44 front axle has c-locks holding the axles in? If so, how do you remove the front axle. If not, will the axle just pull out? It doesn't have a lock screw holding the pinion shaft in, it is a roll pin, or what looks to be a roll pin. Has anyone pulled the axles out? Help needed!
Mint68 is offline   Reply With Quote
Old 11-27-2004, 11:14 PM   #2
1972
Majician
1972's Avatar
The axleshafts are not held by c-clips as the rear axles are. To remove them you have to take off the hub/rotor assembly and then they just slide out.
1972 is offline   Reply With Quote
Old 11-28-2004, 01:39 AM   #3
72 CustomCamper
huh ???
72 CustomCamper's Avatar
Don't forget to remove the spindle...
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 11-28-2004, 03:06 PM   #4
1972
Majician
1972's Avatar
Yep, I forgot to mention the spindle. The spindle can be a PITA to remove. I have a slide hammer type puller that I use to pull it off. AutoZone may rent the pullers.
