11-27-2004, 10:35 PM | #1 |
Center bearing mounting
Hi,
In my haste to get my new project together I purchased a used tranny and driveline. Now that I have installed it in my 69 longbed, I have found that the tranny is the longer tailshaft version and my original driveline is now too long. I do have a driveline from a later truck and it does seem to be the right length however my center bearing mount is the early in-line type and the later one has the more traditional straddle type mount. So, my question is....is there an easy way to adapt, weld, fabricate a mount for the later center bearing/driveline without changing out the crossmember? Or am I going to have to shorten the existing driveline? Thanks Rick
Rick 69 Longbed Project 57 Chevy 406 Four Speed |
11-28-2004, 01:04 AM | #2 |
PROJECT 7DEUCE
I would just shorten the driveshaft and call the problem solved..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
