Old 11-28-2004, 09:13 PM   #1
mocwon
Keep On Truckin'
mocwon's Avatar
Tailgate support cable installation instructions
Here are the instructions that several members requested I post describing the conversion from metal tailgate support straps to cables. The pictures may not be in order but hopefully they still make sense. It will take two posts for all the pictures.
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
Old 11-28-2004, 09:18 PM   #2
mocwon
Keep On Truckin'
mocwon's Avatar
More...
More pictures
Just Passin' Thru
Old 11-28-2004, 09:41 PM   #3
lamar
lamar's Avatar
That is a very neat little add on.
lamar is offline   Reply With Quote
Old 11-28-2004, 10:14 PM   #4
Very clean job and nice write up and good pictures support.. Click, save
Old 11-29-2004, 01:56 AM   #5
shadetree
shadetree's Avatar
Good quality pictures,,,of a very beautiful paint job! Love that color!
1970 long fleet, 355 4 speed, primer, walnut goodies
shadetree is offline   Reply With Quote
Old 11-29-2004, 12:06 PM   #6
sactoC10
71 DELUX
sactoC10's Avatar
nice job
More work than I would have planned on doing...have to reconsider my previous thoughts, nice and clean work...thanks! Is there a way to accomplish this or something similar without cutting, drilling and tappint the "T"? I was going to try and figure out a way to use the T.
5/4 drop LWB wood bed - 15x8 front 235/60 - 15x10 rear 295/50
2003 FORD Escape
1998 Honda VTR1000
sactoC10 is offline   Reply With Quote
Old 11-29-2004, 12:41 PM   #7
chickenwing
Lovin' Life in Miss.!
chickenwing's Avatar
Jeff, I have the taps and grinders. Looks like an afternoon project if yo don't weld in the brace.
Mocwon: Would you be kind enough to list the hardware that you used on the bedside cable mounts? Trying to escape the 3 trips to the hardware store to do one project. Allmost forgot the kudos! Great write-up!
Thanks.
Rich
The truck... you hear that? No really, you did hear that?!!!
chickenwing is offline   Reply With Quote
Old 11-29-2004, 01:18 PM   #8
Custom 68
Custom 68's Avatar
very nice job. Now why did you add the angle brackets? Is it for support? I was not sure why they were needed?
Again that truck looks great!
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 11-29-2004, 02:14 PM   #9
sdkid
This needs to go to FAQ...
sdkid is offline   Reply With Quote
Old 11-29-2004, 06:08 PM   #10
jbw0127
Why?
Just Curious.....
Great mod and done nicely, but is there any advantage to this as opposed to stock?
72 swb Cheyenne
"nut & bolt" frame off (in process)
Blown 383
jbw0127 is offline   Reply With Quote
Old 11-29-2004, 06:14 PM   #11
mocwon
Keep On Truckin'
mocwon's Avatar
Originally Posted by jbw0127
Just Curious.....
For me, its a neatness and updated look. The stock metal bars tend to get easily chipped up and rusty. Functionally, there is no reason to change in my opinion.
Just Passin' Thru
Old 11-29-2004, 06:28 PM   #12
raggedjim
raggedjim's Avatar
I like it, it would probable cut down on the rattling going on in the back of my Blazer...
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743
raggedjim is online now   Reply With Quote
Old 11-29-2004, 06:35 PM   #13
72MARIO
72MARIO's Avatar
Thanks Buddie.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 11-29-2004, 06:42 PM   #14
mocwon
Keep On Truckin'
mocwon's Avatar
chickenwing: the hardware involved other than the Ford Ranger parts is a few washers and the nut and bolt. I didn't keep track of the sizes of the washers, nut and bolt. I just rummaged around through my stash until I found some that would work. Its easier if you already have the cable support so you can find a bolt with the right size head to fit in the hole and work properly.
custom 68: I added the angle pieces for support but I doubt if they are necessary. It's kind of a flaw I have, over-building. But, I know for a fact there will be greatly reduced stress at that point on the end of the bed since the load is now distributed over a larger area.
sactoC10: I sure there are other ways to accomplish the same end result, this just happens to be what I ended up with. I can tell you the late model Chevy truck cables are too long plus millions were recalled by the factory for being prone to failure due to corrosion.
Just Passin' Thru
