11-29-2004, 10:06 AM | #1 |
adding power brakes to inline?
Did the inlines come out with power brakes? If so where did they get there vaccum? Was there a single barrel carb big enough for vaccum without killing power? any pics of booster to carb setups?
11-29-2004, 10:16 AM | #2 |
see the fitting on the manifold directly beneath the carb?
Also note the wierd air cleaner, you will either need to find one like that(good luck) or run a little tiny air cleaner. |
11-29-2004, 02:35 PM | #3 |
Where's my beer?
Moodybo, don't mean to hijack your thread, but i was wondering, GeeEem, i don't see a fan shroud on yours, and my 70 doens't have one either. Did they not come with one on 6 cyl?
11-29-2004, 02:39 PM | #4 | |
Resident Curmudgeon
Here is my six with PS and PB.
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
11-29-2004, 03:17 PM | #5 |
"Trucks with Class"
Fan shroud & PB
Fan shroud: If you ever change radiators, go to a v8 and just move your mounts out to those holes. This lets you run the v8 fan shroud, bolt in. They were offered on some HD cooling sys options that way from GM.
Here is the complete PB air cleaner with all of the hardware incl heat riser tube---and it is FOR SALE--- http://207.44.196.117/vboard/showthread.php3?t=108987 Last edited by PICKMUP; 11-29-2004 at 03:21 PM. |
11-29-2004, 04:29 PM | #6 |
Sleep-Deprived
Frank, that thread is for power steering pumps?
1971 K/10 Long Fleetside 350/350 - 6" Lift 1969 C/10 SWB 292 - Sold It |
11-29-2004, 05:43 PM | #7 |
"Trucks with Class"
Aircleaner
Thanks...I found it! Moodybo, I will hold this 24hrs before I go on to the other guys inquiring about it.
http://67-72chevytrucks.com/vboard/s....php3?t=123828 |
11-29-2004, 08:33 PM | #8 |
thanks pickmup! I already am running a smaller air cleaner! Where the fitting connects i have a threaded plug! i figured that was what it was for. go ahead and pass it on! thanks anyways.
