11-30-2004, 10:38 PM | #1 |
Venting
Well I figured I was messing up on the install of my door poppers so I took the truck out on it's maiden voyage, about two miles from the house. They had my truck for two whole days and I had to call the shop for progress. Normally in my estimation people who work on vehicles call you before the end of the business day to tell you about problems, etc. Not.They told me they got the passenger side to work but not the drivers side. Well after close to the end of the second day, I went to the shop to see what was going on. They told me if I tightened the cable on the passenger side it should work fine. Well, I looked at the passenger side, and the solenoid wasn't even attached to the door. They told me the drivers side would not work with the remote, but would with the push button inside the truck. It did in fact work that way. I asked them what they had to do to get the drivers side to work with the push button? Any adjustment of the cable, etc. I was told no, they only hooked up the push button. But the drivers side doesn't work with the remote. I figure tomorrow I will sort that out. To add insult to injury, When I get the truck comfortably back in the garage, I smell something that is not right, both rear brakes are smelling like they are burning up. I take a little water, and put on the rear wheels and steam like a mother happens. I sure hope the brakes are the culprit and I didn't smoke the whole rear end. Sorry people I just needed to vent. And the bottom line is I paid over a hundred dollars to be just where I was two days ago. I guess what I have been trying to accomplish is harder than most people think. Wootdog
1967 C10 Got it back after three years Boy I sure missed Peppy 1969 Chevelle 1990 IROC Z Convertible 2002 Silverado LT |
11-30-2004, 10:44 PM | #2 |
its all about the +6 inches
On the brakes, does it have a brand new master cylinder on it?
11-30-2004, 11:44 PM | #3 |
Master cylinder?
Yes It has a new master cylinder. I put in a corvette master cylinder with both of the fluid fill areas being the same size. I have a ford nine inch rear end with disc brakes. It has new rotors, new calipers, pads, heck everything is new. It figures the Ford part would give me the dickins so to speak. I pulled the left rear wheel just now, and the pads are definately rubbing the rotor. When I replaced everything a while back, and yes it has been setting for awhile everything was ok. I sure hope I didn't smoke the rear end. I will find out tomorrow evening. The one thing I didn't do was make sure the rear end was full of ninety weight rear end oil. Like everything else it will probably get me in the butt. And I probably needed to put in the proportion valve that I didn't use after I bought it. Kerry
11-30-2004, 11:58 PM | #4 | |
Got Light Emitting Diode?
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car) 1993 Cherokee work ride/weekend wheeler |
12-01-2004, 12:12 AM | #5 |
Re Prop valve
I never installed the darn thing. I am running without a prop valve. could that be my problem?
12-01-2004, 12:14 AM | #6 |
id put it in and then go from there
