Old 12-01-2004, 07:35 PM   #1
Scrubby
Check out GMTrucks.org
pickup door to sub door?
Anyone every converted a good pickup door to a sub door by changing the window frame? My subs passenger door got smashed in a hit and run, and I have a good pickup door. Seems to me I could just cut the corner out of the window frame and weld on the one from the sub door. What do you guys think?
Scrubby is offline   Reply With Quote
Old 12-01-2004, 10:39 PM   #2
RANDY COX
RANDY COX's Avatar
looks to me like that's all youd have to do,and change the glass of course, it would probably be hard to find a replacement original door.won't know till you try.I cut down a truck door to a blazer one time,but that was pretty easy.
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 12-01-2004, 11:13 PM   #3
tjhooker125
Scrubby, the easiest way to do it would be to drill the old frame out at the spot welds, little dimples, where the frame goes down into the door at the front and rear (on the pick-up door you're going to use). The frame that you will be using, (off of your smashed Sub door), you will need either a special spot weld cutter that works in a drill or if you have a die grinder, grind the sheet metal down around the dimple. You don't want to drill through this frame. If you use the grinding method, the sheet metal will turn blue from heat, but the spot weld won't. You'll know when you've ground through, you will see the frame under the door sheet metal. The spot weld will be at the center of the area you grind.
When you're ready to weld, holes will be already drilled in the pick-up door your using from drilling the old frame out. Just check the frame you're welding in to make sure the metal is ground clean under the holes so the weld will stick.
Hope this isn't too confusing and helps. TJ
tjhooker125 is offline   Reply With Quote
Old 12-02-2004, 12:23 AM   #4
68plus4sub
68plus4sub's Avatar
I don't think that sub doors are to difficult to locate, seems like A LOT of work to do on a door when there are doors all around. Just my thoughts. I have seen many doors and sets of doors at swap meets, online, and in the papers. Sounds like to much time to waste to do all that body work. Look around a little (if you haven't already), it may save you time and money in the long run.
1972 Chevrolet Suburban ('68 front clip), 2wd, 350/350, factory tilt
2008 Kawasaki Concours 14
1997 Harley-Davidson Soft Tail Custom
1948 Chevrolet Coupe (project)
1972 Porsche 914
68plus4sub is offline   Reply With Quote
Old 12-02-2004, 11:26 AM   #5
bagged91
Out draggin'
bagged91's Avatar
That may be all fine & dandy in your area with the logging companies,ect... that used to have them but I know where I am at, there are just no Suburbans to be found,Period. Out of the 3 Suburban's in my local area, I have 2 of them. I have thought of doing the same thing with the doors. We have TONS of pickups here and quite a few of them are pretty decent... 1st Gen K5's are more prevelant than the Subs around here too...
91 GMC Xcab LB-Bags/bd/caddy clip SOLD
72 C10 Cheyenne Super LWB SOLD
92 GMC K1500 Burb
72 C10 Burb (ex. Cheesewagon)SOLD
72 C20 Burb parts truck
71 C10 Burb "project"
bagged91 is offline   Reply With Quote
Old 12-02-2004, 01:29 PM   #6
Scrubby
Thanks for the suggestion TJ. I have a spot weld cutter and I don't think it would be too bad to do.
I have looked for doors, and for $100 for crappy doors around here, I can do a lot of fab work.
Old 12-02-2004, 03:07 PM   #7
68plus4sub
68plus4sub's Avatar
I guess we're spoiled out here, lots of 'burbs to be had with not much looking. Overall, I'm always amazed by the number of '67-72 pickups, blazers, and 'burbs out here. I guess they used a lot of them, and unless they were on the coast they stayed in fairly decent shape. I'm from Iowa originally, and everything you see there from this era is almost always rusted terribly. Just another reason to live in the great northwest!!!! And yeah, $100 for crappy doors sure wouldn't be worth it, especially with the skills it sounds like you have. I bought a 3rd door at the big swap meet here last year, and the only thing wrong with it was that there had been a speaker hole cut in it.....$20. I guess that proves the differance in demand. Good luck, hope there is a warm spot down below for the hit and runner!!
PS - sorry for rambling
1972 Porsche 914
Old 12-02-2004, 10:46 PM   #8
daves71k5
burb doors
Scrubby;
I have a good set of Burb doors and I'm here in Idaho too, sent ya a PM about them, let me know.
Dave
daves71k5 is offline   Reply With Quote
Old 12-06-2004, 12:01 PM   #9
Nightrider
Nightrider's Avatar
I've had a post for a drivers door for a while, no find....
] : - 71' burb,5.3,4wd
02' f350.7.3
00' F250-powerstroke
00' Roadstar
84' Eagle model 10
72' GMC
18' camery
12' ZX14R-
Nightrider is offline   Reply With Quote
Old 12-10-2004, 10:43 PM   #10
kwmech
I've done the upper frame swap and it is not all that hard. As posted above, just drill out the spots welds wiggle it loose and move it over and weld it back together.
Old 12-11-2004, 11:26 PM   #11
70chevyguy
hello scrubby i got a 68 panel that im restoring and i had to change the door i udes the truck door and changed the panel top post and it just like they said grind out the welds and change and reweld it that simple!!
thanks, bob
70chevyguy is offline   Reply With Quote
