Life, Be In It.....
![]() Join Date: Oct 2003
Finally making some progress on the cab. The new NOS rockers and repro front cab supports are install. Drip rail shaved and replaced with 1/4 inch round bar. Gas filler neck closed up. The cab is now being blasted and primed.
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows" http://67-72chevytrucks.com/vboard/s...d.php?t=200082 |
#2 | |
Got Light Emitting Diode?
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's ![]() 1993 Cherokee work ride/weekend wheeler |
Life, Be In It.....
Here are a couple more pics. Once the cab in on the frame and the door rehung, the shaven drip rail will be completed.
That's awesome work!!
"Trucks with Class"
![]() Join Date: Jul 2000
What are you blasting with? It looks like sand? That gives a great surface for primer to stick to and takes off all the old rust & filler.
Life, Be In It.....
I am not sure what the blast shop is using, it kind of a pink color. I know it is not sand.
cool,just got done with my bothers cab floor,all four cab supports,rockers,cab corners.A lot more work than everybody thinks
Finish the'71..or bust!
Looks GREAT!!! I wish mine were that far along. Good Work!
The blasting media might be Aluminum Oxide. I use it on my project and it works great. It is a darker 'maroon-ish/red' color out of the container...but once it gets blasted for one or two rounds it takes on a pinkish color as it breaks down. It costs quite a bit more than sand...but it gets the job done nice and quick...and I can usually get 3 to 4 cycles out of it before it becomes too fine to work well. Keep up the fantastic work! ![]() |
#9 | |
should just leave the rail shaved.
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon) WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt. |
man does that look familier!!did all mine some time ago and now is complete thank god! but yours is looking great as well keep up the good work!
gm's are #1 1967 chevrolet short step 1988 chev 4x4 1/2 ton 1989 gmc 1/2 ton 1991 chev 1/2 ton 4x4 1993 Jeep grand cherokee 4x4 And yes a 94 Ford Mustang. ![]() ![]() |
