Old 12-03-2004, 07:49 PM   #1
griesel72
griesel72's Avatar
Help.... I don't know what motor is in my truck
I have always thought that the old 69 has a 307 in her, but i need parts, and wanted to verify before having some pimply faced kid at the parts store proving that i'm an idiot, so i thought i'd look it up. But come to find out, the number on the motor doesn't turn up in my book.
The number stamped on the right side head is:
V1219TXD
Can you help me??
David
1969 K10 Custom 10
1997 Z71
2006 Volkswagen Jetta TDI
2006 King Ranch
1980 Wife
griesel72 is offline   Reply With Quote
Old 12-03-2004, 08:03 PM   #2
john
member #16
john's Avatar
There is a TXD shown as 1975 conv. cab C20, 3500 here/ John
http://www.nastyz28.com/decode.html
john is offline   Reply With Quote
Old 12-03-2004, 09:16 PM   #3
Larry68GMC
Here is what I found:
TXD 1975 350 165 4 conv.cab
I found it at
http://www.chevy-camaro.com/chevy-ca...es.asp?group=6
Hope it helps....Larry
71 GMC LWB 350, Dart Pro1's 200/64cc,10.2:1
RPM AirGap, 224/234 @50 496/518 lift w/1.6 roller rockers, 2500 stall
'05 Dodge 2500 Crew Cab 4x4, 4 inch lift and 35's CTD
Larry68GMC is offline   Reply With Quote
Old 12-03-2004, 09:19 PM   #4
LONGHAIR
Unless you are buying internal engine parts.......it doesn't matter at all. Small block Chevys are the same as far as most things go.
LONGHAIR is offline   Reply With Quote
Old 12-04-2004, 10:19 AM   #5
7T2
Active Member
7T2's Avatar
I found it at
Hmmm...according to that, my engine originally had a 4 barrel carb. Now I don't feel so bad about ripping out that "original" 2 barrel carb and manifold.
7T2 is offline   Reply With Quote
Old 12-03-2004, 09:32 PM   #6
griesel72
griesel72's Avatar
So the cam and lifters i need are basic Small block chevy?
1969 K10 Custom 10
1997 Z71
2006 King Ranch
1980 Wife
Old 12-03-2004, 09:38 PM   #7
Randy70C-10
Randy70C-10's Avatar
Yes, as long as you don't go radical. If a cam is radical in a 350, it will be even more radical in a 307.
Randy70C-10 is offline   Reply With Quote
Old 12-03-2004, 09:40 PM   #8
LONGHAIR
Yup. The only difference you would ever notice might be in performance, but it wouldn't make much difference if the cam is near stock. The same cam would act a bit more radical in a smaller motor.
Meaning, if you put a "stock replacement" cam for a 350 in your engine...and it really is a 307, it will be a little more performance oriented. It would likely make more power and at a higher RPM. The closer the cam is to stock..the less affect this will have.
I guess it would depend upon what you are looking for...
Old 12-04-2004, 01:38 AM   #9
Hooter
My other Love
Hooter's Avatar
the number you need to be looking for is on the left side of the engine behind the cylinder head, usually hard to see and usually covered in lots of grime, the head could be off any motor
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 12-04-2004, 09:32 AM   #10
Blazer1970
Blazer1970's Avatar
The number he posted is the block ID number. It is not on the head, just near the head on the block. It is definitely a '75 - '77 350 from a 3/4 or 1 ton truck.
Blazer1970 is offline   Reply With Quote
Old 12-04-2004, 12:36 PM   #11
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Or try www.mortec.com
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
