Old 12-06-2004, 02:25 PM   #1
PHOENIX
Q-Logic Kick Panel
I might have a few spare bucks after Christmas that I want to send on some q-logic kick panels.
I like the q-logics because they also have the tweeter hole.
I have a non factory a/c truck with the manually operated valves for air into the truck.
On the Q-logic website the kick panels look like the replace the top panel too.
Is this so?
Can someone post a picture of their q-logic kick panels?
thanks
EDIT:
Looks like the Roddoors ones will work just fine with the manual air valve thing. I would prefer to have a tweeter in there though. SO if the q-logics will not fit, Ill get the Roddoors ones.
Here is a picture of Roddoors brand that Jeff posted:
Here is a picture of the q-logics:
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
Old 12-06-2004, 02:31 PM   #2
cochino12
It followed me home?
cochino12's Avatar
Is this so?
thanks
EDIT:
Here is a picture Jeff posted:
http://207.44.196.117/vboard/attachm...d=104908&stc=1
No they dont replace the top panel, just the bottom
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 12-06-2004, 02:33 PM   #3
PHOENIX
Thanks for posting the picture so quick!
Looks like one big piece, any chance of getting a different angle?
I think someone hacked my panels before, Ill have to check when I get home.
Old 12-06-2004, 02:36 PM   #4
cochino12
cochino12's Avatar
Yeah I can get some better pics tonight.
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 12-06-2004, 03:21 PM   #5
78SilveradoSWB
78SilveradoSWB's Avatar
Here are some pictures of mine which I haven't installed yet. They don't replace the original ones in the truck, but mount over the existing ones.
Mitch
1978 Chevrolet Silverado C 10
454 BB, TH400
78SilveradoSWB is offline   Reply With Quote
Old 12-06-2004, 03:34 PM   #6
bagged74
its just $$$$$
bagged74's Avatar
you should check with your local stereo shops about getting a custom fiberglass set built. They would be much nicer than those plastic ones. I suppose I could even build a few sets of fiberglass ones if a few of you guys are interested. i have built several sets for the 73-87 bodystyle, what size speaker are you wanting to run?
bagged74 is offline   Reply With Quote
Old 12-06-2004, 06:11 PM   #7
SCOTI
SCOTI's Avatar
What size speakers do the Q-logics hold?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-07-2004, 11:47 AM   #8
PHOENIX
Thanks, great pictures too.
Now I need to pick out some speakers. I need new 6x9's in the door too.
Ill probably get them to match.
Old 12-07-2004, 11:56 AM   #9
cochino12
cochino12's Avatar
Yes, then throw another pair of 6*9's in the cab corners and you'll be rockin
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 12-07-2004, 11:57 AM   #10
SCOTI
SCOTI's Avatar
What about you pre-75 guys? What are you doing when you mount your door speakers since the door isn't flat where the speaker would mount & these years don't have a panel that covers this area?
Another question.... How deep of a speaker can you actually mount behind those kick-panel style 'pods'? They have mounting locations for component speakers but don't look like they allow for much mounting depth.... which from my research is something mid-range components require.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
