Old 12-09-2004, 04:44 PM   #1
grnddwn
belly dragger
grnddwn's Avatar
Z'ed tranny crossmember
Here's our new tranny crossmember for 2" Z'ed frames
grnddwn is offline   Reply With Quote
Old 12-09-2004, 06:53 PM   #2
phantom dually
Project92 SWB stepside
phantom dually's Avatar
Nice looking piece but I would think it needs a little more support to keep the frame rails from flexing. Kinda like the factory unit which bolts top and bottom of the frame rails.
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
Old 12-09-2004, 09:12 PM   #3
BaggedC10
Under construction!
BaggedC10's Avatar
I agree.
I would prefer the X-member be one solid piece of round tubing and I would not retain the factory ends. The ends looked too "tacked on". A one peice mandrel bent piece would be sweet.
JMO.
2001 Silverado bagged on 22's. *Sold*
BaggedC10 is offline   Reply With Quote
Old 12-09-2004, 10:25 PM   #4
grnddwn
belly dragger
grnddwn's Avatar
Those aren't the factory ends they are actually laser cut for one of our other trans cross members. Unfortunately the pictures don't really do it justice
Old 12-09-2004, 11:12 PM   #5
Shev
Head Peon
Shev's Avatar
Any particular reason it's not a solid piece of tubing (my guess possibly it was that way just for R&D)
'72 Suburban, factory tilt, tach, front & rear AC, front & rear disc brakes, 383/700-R4
Shev is offline   Reply With Quote
Old 12-10-2004, 02:32 AM   #6
BK
BK Built
BK's Avatar
excuse me if im wrong, but wouldnt the u-joint between the yoke and the driveshaft take up most of the angle between the tranny and rear end?
BK is offline   Reply With Quote
Old 12-10-2004, 09:22 AM   #7
smokekiki
Mike
smokekiki's Avatar
When he z'ed the frame it moved the motor mounts and motor up 2".It would be a big angle if You used the stock trans mount.Plus it tucks it up out of the way.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 12-10-2004, 12:29 PM   #8
BK
BK Built
BK's Avatar
how far below the frame did the original auto x-members hang? Im wondering, as i plan to z my frame in the next week or two, and i currently have an ECE auto tranny crossmember which is totally out of the way, doesnt hang down at all. THanks.
Old 12-10-2004, 01:55 PM   #9
72MARIO
72MARIO's Avatar
DroppedChoppedPanel
Just incase you don't know. You tranny and the diffirential should be within 3 degrees of eachother.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 12-12-2004, 12:26 PM   #10
corn
I wouldnt worry as much about the trans output shaft angle as I would with the pinion angle. Take a look at any lifted 4X4 out there, they are WAY off. Heres the x-member I did for mine but Ive now changed it a little(raised 1 1/2")...corn
corn is offline   Reply With Quote
Old 12-12-2004, 03:16 PM   #11
72MARIO
72MARIO's Avatar
That does not make it right.... How often does a lifted 4x4 see speeds of 100 km + ? Not very often and I am sure it's not a smooth ride . Incorrect pinion angle will lead to vibirations and premature u-joint wear. I am sure that [/B]grnddwn[B] is well aware of that though.
2005 TAHOE DD
Old 12-13-2004, 11:01 AM   #12
grnddwn
belly dragger
grnddwn's Avatar
Yeah this isn't our first trip the the store. You will find with bagged trucks that there are alot of variables with driveline angle that have to be compensated for.
Old 12-19-2004, 02:11 AM   #13
BK
BK Built
BK's Avatar
i have the ECE auto tranny crossmember, and i was wondering if i just flipped it over would that work for a 4" z, or if i sunk it into the crossmember a little that should work right?
