For those of yall with spark boxes....
...where did you mount yours in the engine compartment? I have a 6AL, and was curious where you might have put yours.
thanks, Larry
GM 330HP/350, Magnuson 122HH, Tremec TKO 5spd |
What was I thinking??
Box
I mounted my 6a box inside under the glove box I made a mounting plate. I didn't see any place in the engine compartment that I liked.
The only thing I don't like is I can hear the box. If I had a radio maybe I wouldn't.
72 K5 that needs lots of parts.. 71 GMC 3/4 4x4 That doesn't need much which is a good thing I don't think I could aford another money pit... |
How long of a run to your coil? Would this cause any problems if it were too far a run to the coil or pick up?
Thanx for the pics Larry
I'm running a HEI and got rid of the module for the Box. So ar it runs great 100% better than the points
senior member
i mounted mine on the inner fender and just used some bushing for mounting it and had to cut it on an angle sorry i dotn ahve any pics i can get some this weekend if you want, and Cethern why didnt you run the box with ur HEI as well?
69 GMC bagged |
I'am running the MSD 6A box with my HEI, I just took out the 4 pin module.
Got Light Emitting Diode?
i put mine right up by the battery, then the blaster ss coil on the fire wall, in the second picture, if you follow the coil wire from the dizzy over the heater box the coil is hiding right behind the hood hinge
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's ![]() 1993 Cherokee work ride/weekend wheeler |
thanx guys,
Larry
on the firewall
1986 c-10 swb 5/7 drop 20'' coys 1958 belair 2door |
I can't tell form the pics, did yall use the vibration dampers?
I didn't the mount I made seems to work pretty good.
ran out of money
i had a mallory box in my engine compartment but for some reason with headers and everything it would get to hot in the engine compartment and the box would cause like a circuit breaker to pop and the truck would shut off..... so now mine is on front of my rad support.... this allows the cool air to blow across it and i havent had a problem yet.... if i drove it more then i would worry about water getting inside of it..... but since mine has been going onto the trailer and down the track then back onto the trailler i am not to concerned..
best of luck Rat
Modify everything, leave nothing alone!~ ![]() ![]() |
