12-10-2004, 09:44 PM | #1 |
bumper impact strip?
its dark out, so i'll ask y'all...
does the impact strip on the front bumper pop off, or how is it attached? I bought a grill guard and it attaches using the stock bumper bolts, but one of them is behind the impact strip. Thanks, -Nick
-'02 Chevy Avalanche, 5.3L, 4x4... needing a small lift and bigger tires -'72 Chevy C-10(350, bored 60 over)dual flowmasters, 3 on the tree -'85 K5 Blazer,305 NO MORE...350 is in,2" lift,33" Mickey Thompson Baja Claw Radials -dads '70 burb (red, 5-7 drop, 350...) www.geocities.com/userc10/truckhome.html AIM: Auntjoedadda |
12-11-2004, 02:39 PM | #2 |
Professional Grade
Yeah, it does, somewhat. You'll need to pinch two little tabs on the back and push forwards to pop it out. Huge pain in the butt to get them all, and you'll have little holes in your bumper unless you cut it so the grill guard will fit.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
12-11-2004, 05:01 PM | #3 |
i am planning to just cut a small section out so that i can get the bracket into the bolt...Thanks for the info
12-16-2004, 01:07 AM | #4 |
They are also hard little buggers to find when you need a new one for a resto....so far i have a stash of three for the 73-80's...
DW
Doug Wright aka K5NUTT over @coloradok5.com Owner of http://groups.yahoo.com/group/ChevyK5BlazerChalets Certified K5 Nut |
12-16-2004, 01:50 AM | #5 |
Professional Grade
Shoulda told me... I buried two of them in mint condition under a couple thousand lbs of concrete as a stiffener...
12-16-2004, 03:21 PM | #6 |
Mudslides 'r my specialty
Can you post pics of the bumper guards installed after cutting the impact strip?
Always on the lookout for old cars and parts...(20s, 30s, 40s, 50s, 60s, etc.) http://www.cardomain.com/memberpage/500339 |
12-16-2004, 03:26 PM | #7 |
yeah, i wont have a chance to do it til probably sometime next week...plus its freezing outside...i'm thinking of mounting it with the bottom bolts, marking where the tab hits the strip, and then using a grinding wheel to cut it out
12-30-2004, 10:34 PM | #8 |
Any luck with this?
12-30-2004, 11:11 PM | #9 |
yeah, i mounted it last night actually...I will try and get some pics tomm. I'm not completely done...i need to clean up the pieces i cut out to put back on top of the bolts.
01-08-2005, 12:52 AM | #10 |
sorry it took so long for pics...it was always dark when i could take them
01-08-2005, 12:59 AM | #11 |
Happy to be here
That turned out nice. It looks much better than if you had mounted it on top of the strip....
01-08-2005, 01:20 AM | #12 |
yeah, i like it...we pulled the bumper off and marked where the mounts sat and used a grinder to take off just the area that was needed...you can tell if you get right up on it but its not that noticable....i need to clean it up a little still
