Old 12-13-2004, 11:29 AM   #1
kevin from oc
kevin from oc's Avatar
tank selector switch
I found what i think is a tank selector switch in the wrecking yard it was on the left side of the dash and it has three settings left, right and center. What are these worth??
kevin from oc is offline   Reply With Quote
Old 12-13-2004, 12:57 PM   #2
ddsmith
Glowing since 1978
ddsmith's Avatar
If I'm not mistaken that is the switch which selects which tank sender is feed to the fuel gage. My C-20 has three tanks but no selector switch for the fuel gage. You just run on one of the Aux tank until the truck starts to die then reach down to the tank selector valve on the floor and select a different tank. This can be pretty exciting on the Washington DC beltway with a tractor trailer on your a@@. The gas gauge only registers the level in the behind seat gas tank. I know this truck is factory equipped with the three tank configuration. Maybe newer trucks or dealer installed option trucks had the gas gauge selector switch. I'm not sure about price but I'm sure one of the experts will be along to help.
66 Chevy C30 Stakebody Dump, PS,PB, 327cu in
71 Corvette Coupe 454 4 speed
69 Chevy C20 Custom Camper
ddsmith is offline   Reply With Quote
Old 12-13-2004, 01:05 PM   #3
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
My Blazer has the dealer installed Hickey tanks. The selector is on the floor in front of the driver's seat. There is only two positions, one for the main tank and one for the two aux tanks. The gage doesn't work with the aux tanks. I can see the tops of the tanks and there isn't even any indication that there is a float or any electronics to measure the level. Ya just do what ddsmith does, run until the truck starts to sputter and then switch. Because of that, I don't really use them, just enought to keep the gas from going bad.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 12-13-2004, 01:09 PM   #4
JayDubBlazer
go cyclones
JayDubBlazer's Avatar
I don't think they would be worth that much inless somebody is doing a restoration.
Wes
PROJECT OLE GREEN
1972 Blazer 4X4 350/700R4
2017 Silverado LT
JayDubBlazer is offline   Reply With Quote
Old 12-13-2004, 02:18 PM   #5
tkeduk8r
tkeduk8r's Avatar
I have seen the switch he is talking about.... it goes where the A/C vent is located on the left side of the dash tween the door jam and ammeter... I always thought it would be cool to do a three tack set up pirating a set up from a dual tank 73-79 and using that switch in a 67-68 dash set up so you could have the extra spot on the bezel for it...would be some work, btu could be done... but anyway the switch has the same knob as the headlights, WS wipers, choke etc... couldnt tell you if is reads fuel level in the saddle taks though.... hope that helps..
--Mike
63 C20 2WD, 230/SM420/4.11 73K
68 C30 dump truck, 327,SM425,4.56 66K original
68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes
68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79
69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi...
70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP
72 Chevy K20 4x4 350/350/205/4.56 donor
72 Vette 350/M21/3.70 posi, triple black and super fast
84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's
tkeduk8r is offline   Reply With Quote
Old 12-13-2004, 02:36 PM   #6
Solver
Solver's Avatar
My 72 3/4 has aux tank and does have a nob to the left of the guages (right above the a/c vent). It switches the power for reading the level in both tanks. Mine must have a sending unit in it.heres pic of knob location
  • 1972 Cheyenne Super 20 LWB-Blue
  • 1972 Cheyenne Super 10 LWB-Black
  • 1972 Cheyenne Super 10 LWB-Red
  • 1972 Cheyenne Super 10 LWB-green
  • 1972 GMC 4x4 LWB-White
  • 1971 Cheyenne 10 LWB-Ochre
  • 1971 Cheyenne 20 Longhorn-Copper
  • 1971 Cheyenne 20 Longhorn-Black
  • 1969 Custom 10 LWB-lt blue
  • 1968 GMC 3/4 ton-green
  • 1968 1/2 ton swb stepside-silver
  • 1967 Chevrolet CST 10 LWB-green
  • 1967 Chevrolet custom 20 LWB-Maroon
Solver is offline   Reply With Quote
