my guage doesnt work.
how do i tell if my volt guage is bad? it does nothing as of right now.
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon) WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt. |
ttt
its all about the +6 inches
Volt guage?
You talking an aftermarket voltage guage...or the stock amperage guage? |
stock 67-72 guage.
look on both sides of the engine compartment in the wire harnesses. You're looking for small black rubber inline fuses on both sides.
You probably have one or two blown fuses. |
my wire harness runs on top of the rad support....then through the drivers fender to the firewall....which part of it will they be in? doesn't the brown wire from the alternator go directly to the guage?
That's weird, I'm having trouble with mine too. I'm getting power through the fused wire to the gauge so I guess mine's bad. My Granddad installed an aftermarket gauge under the dash so it's cool for now. Is there any way to use an ohm meter or something to check it?
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck |
Still drivin' a Rat Rod
lol I never had one that worked,figured when the battery was dead,something was broken.Maybe i should check into the fuses as well.
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website |
The fuses Andy is referring to are on the front corners of the wiring harness---where the fender and radiator support meet. Little bitty things but inline. Usually break just trying to inspect them. Most common cause for gauge failure.
ty
Excelsior, You Fathead.
I never rely much on the facto0ry gauges, I might put in aftermarket one day but until then, if it don/'t start, somethings wrong
Go Navy. The Sea Is Ours. Budget 350 Build http://67-72chevytrucks.com/vboard/s...38#post2264638 |
member #16
![]() Join Date: Dec 1999
diagram
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
