Old 12-21-2004, 02:47 PM   #1
low 84
low 84's Avatar
will 91 k5 bumpers fit 80 k10?
buddy at work has some nice bumpers of his 91 blazer that he said i could have for the '80. will they bolt up?
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 12-21-2004, 03:07 PM   #2
bigblock73
yeller
bigblock73's Avatar
No.
I believe the brackets are different, as are the frame mounting points. The bumpers themselves also look different, the 81+ bumpers are more squared off as opposed to the 73-80 more rounded bumpers...at least the fronts anyhow.
bigblock73 is offline   Reply With Quote
Old 12-25-2004, 11:12 AM   #3
Grim Reaper
Not a bolt on but it can be done. The front of the 90 will have some brackets bolted on the top of frame horn. Little metal work on the 80 frame horns and you can bolt those brackets on.
Grim-Reaper
70 Pontiac LeMans Sport Convertible, worlds longest resto in progress
Looking for 71-72 2wd Blazer or Jimmy Project
Grim Reaper is offline   Reply With Quote
Old 12-27-2004, 04:45 PM   #4
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
You need to do this for the front:
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 12-27-2004, 08:32 PM   #5
low 84
low 84's Avatar
so you just have to trim the horns some and everything will bolt up? does the rear bolt right up?
'05 1500 Crew Cab
RIP
Old 12-28-2004, 06:23 PM   #6
Captkaos
Captkaos's Avatar
Originally Posted by Riptide's 78p/u
hey chris...do u know approximatly how much u have to cut off? cause im doint the same thing to my frame..and dont wanna screw it up
From memory it was 2.5" from the line to the far most point of the frame. If you have the 81-87 bracket, it will give you a guide to cut at.
Yep, you do have to have the front 81-87 brackets though. The rear should be the same, I don't think the bumper mounts points changed, just the look of the rear bumper.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 12-30-2004, 06:29 PM   #7
SCOTI
SCOTI's Avatar
http://67-72chevytrucks.com/vboard/s....php3?t=133497
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
