Old 12-21-2004, 04:47 PM   #1
mocwon
Keep On Truckin'
mocwon's Avatar
Question Location for tuned port wiring harness hole in firewall???
Just about to the point of installing the Painless wiring harness for the tuned port injection. So, I'm curious where those you with tuned port setups made the hole in the firewall for the harness leading to the ECM?
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
Old 12-21-2004, 07:31 PM   #2
Deuce
Deuce's Avatar
How did you find the overall quality/ease of install of the painless TPI harness??
I'm doing the same conversion and I was thinking about the painless harness as well if I don't use the stocker.
I know what your thinking.......I have ESPN.
Sometimes it's easier to do things the hard way.
Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!!
Deuce is offline   Reply With Quote
Old 12-21-2004, 08:33 PM   #3
71swb4x4
71swb4x4's Avatar
I put my hole right behind the pass side valve cover. From the interior it comes in behind the heater box. It took a really large grommet. I still need to seal my hole as well, but I have to pull my harness again before I seal it.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 12-21-2004, 11:24 PM   #4
bagged91
Out draggin'
bagged91's Avatar
I would be interested to know how the painless harness works out too. I have a fully polished TPI and the complete stock harness, sensors, ECM & MAF waiting to go into something but I look at the stock harness & scratch my head. I bought the book from JTR (Jags That Run) but it still makes no sense to me....
91 GMC Xcab LB-Bags/bd/caddy clip SOLD
72 C10 Cheyenne Super LWB SOLD
92 GMC K1500 Burb
72 C10 Burb (ex. Cheesewagon)SOLD
72 C20 Burb parts truck
71 C10 Burb "project"
bagged91 is offline   Reply With Quote
Old 12-22-2004, 01:14 AM   #5
Deuce
Deuce's Avatar
I bought that book too. Kinda useless as far as doing a TPI conversion. I was told to buy the Helms manual to help figure out the wiring.
Old 12-22-2004, 01:51 AM   #6
Russell
Professional Grade
Russell's Avatar
www.chevythunder.com has absolutely everything you need to know for making your own harness I can help with any MAF wiring harness questions
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 12-22-2004, 10:31 AM   #7
mocwon
Keep On Truckin'
mocwon's Avatar
Russell
You just opened a can of worms... I bought the Painless harness and have never put one of these in so I'm sure I'll be taking you up on your offer of help. I did buy a couple of books on the topic so I know more than I did at one time but I'm sure I'll still need help. Thanks
Just Passin' Thru
Old 12-22-2004, 08:30 AM   #8
NPilot1975
NPilot1975's Avatar
I am running an LT-1. I got the painless harness with extra length and mounted the computer under the passenger seat. I ran all the harness wiring down the inside of the framerail. The painless harnesses are great, I have the LT-1 harness and the chassis harness.
1972 Blazer body...need to get a thread started for the rest of the story
NPilot1975 is offline   Reply With Quote
Old 12-22-2004, 04:23 PM   #9
Russell
Professional Grade
Russell's Avatar
Are you saying you already bought the painless setup, but are not installing it in favour of making your own? Cause I would highly suggest the painless harness if you already have one. If you don't have one, it is much cheaper to make your own, but you need a basic understanding of how the system works and how everything interacts. It all makes sense after you get to know how it all works together
Old 12-22-2004, 05:14 PM   #10
mocwon
Keep On Truckin'
mocwon's Avatar
I bought a Painless wiring harness and will be using it. I just figured I'll probably run into some opportunities along the way and may need help.
Thanks, Greg
Just Passin' Thru
Old 12-22-2004, 06:18 PM   #11
Deuce
Deuce's Avatar
Thanks, Greg
Can you post some detailed pics of the harness?? It might help the rest of us who are going to try and use the stock GM harness I would name my 2nd born after you!!
Old 12-22-2004, 09:43 PM   #12
WRMZ71
Cause the Chicks DIG IT!!
WRMZ71's Avatar
That has got to be one of the worst cases of thread hijacking i have ever seen. Ladies and gents why don't we keep to what the original intent of the thread was.
WRMZ71 is offline   Reply With Quote
Old 12-23-2004, 01:25 AM   #13
Russell
Professional Grade
Russell's Avatar
This is one situation when keeping your opinion to yourself probally would have been best... Kinda makes you look like a bit of an old grumpy man, lol!
The original question was anwsered, and now we are covering the rest of the bases
Old 12-23-2004, 01:31 AM   #14
Deuce
Deuce's Avatar
If that was the case you'd have nothing to complain about!!
So how about those pics
Old 12-24-2004, 01:04 AM   #15
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
passenger side,just about in line with the valve cover.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 12-24-2004, 05:33 PM   #16
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
I put mine in the same place. Right below the vacuum lines for the heater. Just remember to run your fuel pump relay wires thru the grommet before you put it all in. Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
