Old 12-22-2004, 02:25 PM   #1
81chevystep
ShadeTree Kustomz
81chevystep's Avatar
pics of triagulated 4 link
here they are
-chris-
1981 c/10, 383 fully built bagged, custom interior. built entirely by me
81chevystep is offline   Reply With Quote
Old 12-22-2004, 03:28 PM   #2
r0lf-
Hotwheels?
r0lf-'s Avatar
Pretty sweet man! Im gonna cry the day im gonna need to put in a 4 link for my rear. I have a feeling once those bags go in the front of mine, the rear wont be too long to follow. Oh well, atleast it will handle like a champ
1978 Money Pit - CUSTOM DELUXE!!!!
r0lf- is offline   Reply With Quote
Old 12-22-2004, 05:19 PM   #3
Izzy
Trucker.
Izzy's Avatar
Is that a suicide doors 4 link?
The only reason I ran the parallel over the tri was the shortness of the upper bars.
Izzy is offline   Reply With Quote
Old 12-22-2004, 07:20 PM   #4
RockHQ
ROCKET POWER!
RockHQ's Avatar
looks great, except for a few things:
1. Your parallel links have the air bags awfully close to the pivot point on the frame, how much pressure do you need in the bags to get to drive height?
2. The triangulated link brackets are welded to the banjo, which isn't a very safe thing to do in my opinion (nodular cast iron combined with steel will not create a strong weld).
This is supposed to be constructive criticism, i'm curious to know what your thoughts are?
What did i do last nite?
I had a wonderful time,
That's what they tell me
1979 C-10 shortfleet: Olds 350, Th400, 12 bolt
Current project: 1969 Olds 455 W-30, needing a rebuild
RockHQ is offline   Reply With Quote
Old 12-22-2004, 10:02 PM   #5
81chevystep
ShadeTree Kustomz
Yes it is fron suicide doors
the bag mounst are mounted so close to the pivout points becuase that is where i get the most lift(i get about 12" of lift)
i should not have a problem with welding the uper link bars to the pumkin, i have done several trucks like that and some of them have been on the road for a few yeas now
thanks for the coments
chris
ps here is the money shot
-chris-
Old 12-22-2004, 10:34 PM   #6
lolife99
67-72 parts collector,…
lolife99's Avatar
Just a question. Shouldn't the upper pivot points of the 2 bars, (short and long) be in the same vertical plane? Like both on the axle tube centerline? Just looks like it would rotate the pinion angle, as you air'd up and down. I thought a 4-link should keep the pinion angle pretty close, through its full length of travel. I know the triangulated 4-link helps control "side-to-side" movement,...Sorry,... maybe just a stupid question. Any comments would be appreciated.
Keith
Convert to disc brakes.
Old 12-23-2004, 11:15 AM   #7
bagged74
its just $$$$$
bagged74's Avatar
yeah, what he said. The pivot points should be on the same plane. It looks like you are going to have some pinion angle problems. I know it will probably work, but that doesn't necessarily make it correct. Maybe i'm wrong, but the geometry does not look good to me.
bagged74 is offline   Reply With Quote
Old 12-24-2004, 12:46 AM   #8
raceman6135
Dino burner
raceman6135's Avatar
In addition to pinion angle problems, there will also be a change in the vehicle's wheelbase when the upper and lower links have different front rotation points.
That's caused by the rearend trying to rotate in two different arcs.
DJS
raceman6135 is offline   Reply With Quote
Old 12-22-2004, 10:37 PM   #9
78chevstepside
78chevstepside's Avatar
Iam suprised the mild steel to cast would hold at all .
78chevstepside is offline   Reply With Quote
Old 12-22-2004, 10:47 PM   #10
low 84
low 84's Avatar
so what steps did you take to weld the tabs to the center section? did you preheat and use a special filler material or???
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 12-23-2004, 03:02 PM   #11
bagged81
Signals in the bumper.
bagged81's Avatar
Did I miss something? When did you get the front that low?
Jeff C.
1981 Chevrolet Silverado - Under major construction...again. link
1962 Chevrolet Impala 4D Sedan moredoorclassics.com
1936 Ford Pickup - Frame-off in progress link
1979 Chevrolet Camper Special Flatbed link
bagged81 is offline   Reply With Quote
Old 12-23-2004, 06:26 PM   #12
AirMale
AirMale's Avatar
I doubt those welds could pass tech at my track. I was thinking about maybe a boxed brace that can bolt to the 10 or 12 bolt cover would work better for a triangulated 4 link. I think I'm gonna play with my plasma cutter and see if I can make a template that will sit on top of the rear cover and utilize all 12 bolts. I've yet to see a triangulated set up for our frames that can be used with a 10 or 12 bolt rear.
86 SWB 9.0 LITER
T-400-OD 4.11 eaton-4/5 drop
Best 1/4 12.51 @112mph no traction
AirMale is offline   Reply With Quote
Old 12-23-2004, 06:56 PM   #13
RockHQ
ROCKET POWER!
RockHQ's Avatar
The ultimate version would be a rear end cover, that's also a mounting bracket for the tri-links and is sturdy enough to use bearing cap support studs. Then again, it would be mounted with 1/4" bolts to the pumpkin without any dowel pins to locate it securely.
Old 12-23-2004, 07:05 PM   #14
81chevystep
ShadeTree Kustomz
yeah the more i look at it the more i realized that i need to change the position of the uper links.
thanks for the input guys
chris
-chris-
Old 12-24-2004, 12:49 AM   #15
raceman6135
Dino burner
I know this isn't quite what you're describing, but here's an axle tube brace and a rear girdle assembly. Courtesy www.lpwracing.com. Good springboard for some custom fabrication?
DJS
Old 12-24-2004, 04:23 PM   #16
Izzy
Trucker.
Izzy's Avatar
You could do a center support similair to this Rob Roddell piece.
Old 12-23-2004, 09:53 PM   #17
lolife99
lolife99's Avatar
I think I've seen a bracket that "sandwiches" between the rearend, and the cover. Mount some studs in the rearend housing (and use two gaskets),... then build your upper link mounts off that. Just a thought.
Keith
