Old 12-24-2004, 11:32 AM   #1
krazy_texan
krazy_texan's Avatar
tansmission?
can you change out the tailshafts on a trans say i have a long tail turbo 350 but i need the the short tail off of the old one can i just swap them out and put the good transmission in the truck or do i have to find an actual short tail tranny. thanks for any help guys
merry christmas to all of you guys
Krazy Texan
My Trucks are made with Wrenches not Chop Sticks
1967 GMC 3/4 ton "Johnny Cash"
1990 v1500 suburban
1967 Ford f100 Swb 4x4 "green bean"
GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO
krazy_texan is offline   Reply With Quote
Old 12-24-2004, 11:39 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
IIRC, you need the main shaft out of the tranny too...totall disassembly.
Old 12-24-2004, 11:42 AM   #3
crazy longhorn
Fabricate till you "puke"
you can swap them, but you will need to completely "gut ' both trannys to do the job. The tailshaft is the 1st pc to go into the case!. just a thought.....you might think about a shorten & balance on the D shaft. Good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 12-25-2004, 09:51 PM   #4
jimfulco
A local trans guy quoted me $75 for a gut swap if I had all the parts, but that was a couple of years ago. The 9"-tail stuff is not real easy to find compared to the short stuff, so your old stuff might be worth salting away for later.
jimfulco is offline   Reply With Quote
