12-24-2004, 01:11 PM | #1 |
Standard trans?
What is a good manual shift trans for a 307 or 350 engine? Also how hard is it to swap from an auto trans to manual shift trans? The truck was originally 3 on tree but prev. owner swapped to turbo 350 auto so the clutch pedal is already in the truck. I am considering manual with floor shift. Any Thoughts?
Have a safe x-mas. |
12-24-2004, 02:38 PM | #2 |
I am in the process of swapping the old 4-speed out for A TH400. My preference. I like the idea of putting A newer 5-speed from A later model truck. I dont know what is involved. (crossmember attatchment). Good luck!
Gary
"72" Red CORVETTE 4-speed 350 "70" Chevy Short Bed early stages of resto. Edel 600 cfm carb Weiand Stealth Intake HEI shorty Headers 4/2 Drop 295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners. "CHEVY RULES" |
12-24-2004, 04:01 PM | #3 |
hart
Do a search on t-5 If you want a five-speed. The later model trucks 5-speed has an electric spedometer Which I hear can be pricy to convert
12-24-2004, 04:49 PM | #4 |
I will be taking the turbo 400 out of my 3/4 ton one of these days -if I can ever find the time- and putting in a Muncie sm-465 4 speed. It has a good reputation, tough as nails they say. You will probably need a drive shaft from a standard trans truck, a manual trans crossmember, clutch pedal and all linkage (z-bar, etc.) Also, you will need to drill and tap a threaded hole for the z-bar into the block (drivers side) unless it's there already. And I beleive the neutral safety wiring will have to be changed to a manual set-up. The low-hump trans cover will have to be changed to a high hump. Can't think of anything else. Best of luck.
1969 G.M.C 3/4 Ton 920 (Canadian Version) 307 3 speed, currently apart 1998 Chevy 1/2 ton ex cab V-6 5 speed 1967 Chevy SWB - project truck; not started just yet |
12-24-2004, 04:57 PM | #5 |
I'd recommend against the T5. They are a light duty transmission & will not stand up 350. I wouldn't put a T5 behind anything bigger than a 6 cyl.
85' CUCV M1009!!! The newest addition! 6.2diesel, Th400, NP208, & only 36k miles! 70' C-10 LWB Fleetside - Looking good these days! 05' Dodge Neon 88' Winner Escape Sport 1750 - 4.3v6 94' Seadoo SP 84' Honda TRX200, bare nekkid. Just a frame & tires. Always looking for another project or any good deal! |
12-24-2004, 05:34 PM | #6 |
Active Member
I swapped out a 3 spd Saginaw with a 4 spd Muncie. Easy swap with no problems. The engine was originally a 307 thap was pulled and a 350 installed.
69 C10 LWB Project 47 Cushman Scooter Project It is better to have loved and lost than to live with a psycho all your life. |
12-25-2004, 04:12 AM | #7 |
If you have $3000 burning a hole in your pocket, search on Richmond 6-speed.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. |
02-19-2005, 03:20 PM | #8 | |
Broke and still trying
02-19-2005, 07:21 PM | #9 |
A classic GM kinda guy
My thoughts:
Hit the following website:
www.keislerauto.com Either the TR 3550 or T56 conversion would work great. Been thinking about either for my next project.
Old school rap music: a dual exhausted GM 6 with no mufflers. "If you can find a better vehicle, buy it" Lee Iacocca, Chrysler commercials of the '80s. "I did. They are called Classic GM pickups !!!" |
02-19-2005, 09:09 PM | #10 |
Speed Limit = Floorboard
[QUOTE=inline6Bill]Hit the following website:
www.keislerauto.com Either the TR 3550 or T56 conversion would work great. QUOTE] I want the T56 bad, but it'll have to wait for awhile.
1971 C20 350, 4-speed - Sold. 1985 K10 350, Built 700r4, Edel 1406, Performer intake, MSD Ign, Hooker Comps, Silverstars, Piaa drivers, LED tails, Toyo A/T 31's, Eaton Posi, the project. "Build for torque, horsepower will follow" |
