Old 12-28-2004, 12:21 AM   #1
67pro-street
67pro-street's Avatar
700R4 question
I am installing a 700r4 tranny in my truck. It is taking place of the original 4 spd manual tranny. my engine and tranny were originally in the I-6 position and are now moved to the 350 position. I was wondering if anybody else out there who has done this conversion would know how much i need to shorten my drive shaft for the new tranny. I also have a 4/6 drop on the truck. If no one knows that, could any one tell me how far out the yoke comes from the tailshaft on a 27 spline transmission. That way i could compensate for the yoke and take my measurements myself. Thanks in advance,
67pro-street.
67pro-street is offline   Reply With Quote
Old 12-28-2004, 02:11 AM   #2
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Well when I installed my 700R4 into my Blazer.I moved the eng forward and just redrilled a couple holes.This meant I could retain the tranfer case mounting position and keep my front and rear drive shafts at stock length.
I moved my eng towards the rad approx 1"7/8" from the standard V8 location
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 12-28-2004, 09:45 AM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I converted a 6 cylinder truck to V8 and 700r4. The original driveshaft on the truck was a 1 piece shaft.
By the time I moved the engine forward and put the V8 frame stands in and then the 700R4 being longer, the stock driveshaft worked perfectly. No mods needed. Mine was an origianl 3 speed truck too by the way.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 12-28-2004, 06:09 PM   #4
crazy longhorn
Fabricate till you "puke"
Slide the slip yolk into the trans till it bottoms....then pull it back out 3/4" minimum, to 1" max , & then you can measure c to c on the shaft. im not sure if you have a short or long wb truck, but if you are under 70 or 71 " c to c on the caps, I would look at a 1 pc shaft. best of luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 12-28-2004, 06:27 PM   #5
67ChevyRedneck
67ChevyRedneck's Avatar
I have a 1 piece shaft, 67 swb, that was an I6 3sp converted to a 350 700R4 in the stock V8 location and I think I had to shorten my shaft about 5 inches or so. I don't know a lot about the 3 speeds, but the 3 sp in my dad's 69 was a lot longer than the 3 sp in my 67. I was told GM made two different 3 speeds, one with a long tail and one with a short?? I measured mine like crazy_longhorn said and took it to a machine shop.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 12-28-2004, 07:20 PM   #6
67pro-street
thanks for the help guys. i do have a long wheel base truck and i am pretty sure that the original tranny was a short tailshaft. will this make a differnce. once again, thanks for the help
67pro-street
Old 12-28-2004, 10:22 PM   #7
guyryan100
guyryan100's Avatar
To be safe, just wait till the tranny is in and you can measure it out right. I did the swap, had a 3spd manual before, and had to cut the shaft about 2" for the 700r4. I'm told that the 700r4 may have a different length based on the donor vehicle.
guyryan100 is offline   Reply With Quote
Old 12-29-2004, 09:00 PM   #8
BobM
I did this conversion with my 71 Fleetside LWB. Used the original two piece drive shaft with out any modification. Turned out that the 700R4 tail shaft was about 1/2 inch further forward than the three speed manual, so wasn't a problem. Engine is in the V8 position. 700R4 is out of a 87 Pontiac.
BobM is offline   Reply With Quote
