12-29-2004, 05:33 PM | #1 |
question about tires
Sorry to ask so many questions lately but I am trying to get everything up to specs on my truck, so here is yet another question what should the tires be torqued to on a 1969 chevrolet CST-10 Pickup with Firehawk Indy 500 tires. Also I'm not sure if they are the right tires because the stubs only come out about 1 or 2 inches. Help!!!!!!!!!!!!!!!!!!!!!!!
12-29-2004, 11:14 PM | #2 |
20' Daredevil (Ret)
Gotta say I really have no idea what your question is, sorry. If you want to know the torque for the lug nuts, 90 to 95 lb/ft should do it - doesn't matter what tires are used. If that's not your question, I'm afraid I can't help you - tires don't get torqued, and what stubs are you referring to?
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
12-29-2004, 11:39 PM | #3 |
lug nuts, sorry I call them stubs, the other part of my question is if those things that stick out of the drum that the tire mounts to are like only 1 or 2 inches would that be safe to drive on?
12-29-2004, 11:47 PM | #4 |
It depends on how far the studs stick out after the wheel is mounted. You should at least be able to say that half of the lugnut has been engaged. So, whatever lugnut, wheel, stud combo that you are using. Half of the threads of the lugnuts should be used. If this doesn't clear anything up, just let me know.
-Greg My Chevy trucks, past and present: 1962 C10 SB Fleetside 1964 C10 LB Fleetside BBW 1966 C10 SB Fleetside 1966 C10 SB Fleetside BBW 1968 C10 SB Fleetside 1971 C10 LB Fleetside 1971 C10 SB Fleetside 1972 C10 SB Fleetside Cheyenne 1972 C10 SB Fleetside Cheyenne Super 1972 C10 LB Fleetside Cheyenne Super 1974 C20 Cheyenne 1979 K5 Blazer Cheyenne 1982 K10 SB Fleetside Custom Deluxe 1982 K10 SB Fleetside Scottsdale 1986 C10 SB Fleetside Silverado 2008 Silverado 1500 4x4 |
12-29-2004, 11:47 PM | #5 | |
Got Light Emitting Diode?
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car) 1993 Cherokee work ride/weekend wheeler |
12-29-2004, 11:52 PM | #6 | |
12-29-2004, 11:47 PM | #7 | |
12-29-2004, 11:48 PM | #8 |
20' Daredevil (Ret)
The wheels slip over the lug stuDs and are held on by lug nuts, which thread onto the studs. With the wheels properly mounted and the lug nuts properly tightened, as long as the studs are sticking out beyond the lug nuts at all, you are safe.
