Old 01-01-2005, 10:02 PM   #1
402Bowtie
402Bowtie's Avatar
Big Block and 4x4 Question
I have a 402 big block I would like to put in my '72 K20. There recently were a couple of threads talking about this, but I couldn't find them. If I remember right there was someone who had to cut out some of the firewall of their cab in order for the bb to fit. What is it about a 4x4 that creates a problem with a big block, and what modifications will need to be done in order for everything to fit?
402Bowtie is offline   Reply With Quote
Old 01-01-2005, 10:06 PM   #2
Yukon Jack
Yukon Jack's Avatar
I had to modify my firewall but some people have to do nothing, not sure why. You can see some pages on my website in my signature where I detail putting the bb in my 69 K20. Big blocks are taller and wider than small blocks.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 01-02-2005, 01:18 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
A body lift will help quite a bit too.
not only does the size of the engine make it a PITA, but the 4X4 trucks have the engine sitting back further than a 2 wheel drive does...that's why you can get them in 2 wheelers, but was never an option in 4X4 trucks.
Old 01-02-2005, 02:13 AM   #4
402Bowtie
402Bowtie's Avatar
thanks guys, that was exactly the info I was looking for. Why then do the engines sit farther back on the 4x4s....is it for clearance issues somewhere? Forgive me if this is an obvious answer, but I am a learning 18 year old...thanks...John
Old 01-02-2005, 02:18 PM   #5
kwmech
Body lift to clear the rear of the cylinder heads, or you can move the x-member forward and redo the drivelines like I did. The only other modification would be the x-member itself for possible clearance of the oil pan--depending on the pan.
Old 01-03-2005, 01:35 AM   #6
4x4Poet
Doesn't moving the engine xmember foward also move the oil pan's rear sump within shot of the axle and/or diff pumpkin cycling up?
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 01-03-2005, 01:41 AM   #7
MAC67
" SHOW ME"
MAC67's Avatar
when i set the bb in my blazer i hardly had to do anything , the only firew wall mods i ddi was 2 eggsized dents i put into the firewall for valve cover clearance , it does have a 3 inch body lift which i dont like but it made it easier ,, you cant even see the dents when the motors in , they are very small
MAC67 is offline   Reply With Quote
Old 01-03-2005, 01:42 PM   #8
kwmech
Still clears--may have a problem with the factory flat leafs, not with a 4'' lift
Old 01-03-2005, 08:10 AM   #9
Personally,I keep the big blocks for street(2wd)trucks.You can get how ever much power you want from a small block for 4-wheelin`and they are lighter.I think the idea sounds cool,great braggin`rights,but I`ve never done it,never needed to.
Old 01-03-2005, 01:09 PM   #10
MAC67
" SHOW ME"
MAC67's Avatar
never gonna pull the same torque out of a small block that you will a big block , sure they are a little more expensive , the weight difference isnt enough to make to squirts , you really ooughta try it sometime ,
Old 01-04-2005, 02:18 AM   #11
Pont
I need another Barley Pop
Pont's Avatar
I'm also running a BB in my 4x4. Fit's tight, no firewall mods, no body lift and not enough room for an HEI so I opted to go with a Mallory Unilite dizzy. The stock exhaust manifold would not clear the passenger upper frame rail and it had to be notched (or ground) to clear. Same issue with the headers I now run. Hope this helps...
67 Short Fleet 4x4
04 Honda CRF450R
89 Toyota 4-Runner
34 Ford 2 door sedan - Long term project
There is a very fine line between "hobby" and "mental illness"
Pont is offline   Reply With Quote
Old 01-04-2005, 09:15 AM   #12
I knew I`d get a reaction from you,Mac67.Not trying to raise hairs.I just never bothered with it.I wanted badly to buy Bad4x4`s 454-powered K/20,too far.With 4wds I look for torque from gearing;axles&T-case gears.Ever wheel a doubler equipped rig?If I was to swap from a small block out for more torque,I`d run a diesel.Worth the added weight in torque(like a big block,just more).And,you get fuel injection,another off-road plus.I plan on this one day.Meanwhile,I`m content with the power from the 400,383,and even the 350 powered trucks I have.
Old 01-04-2005, 09:35 PM   #13
too much stuff
Roadtrip!
too much stuff's Avatar
Couple things i found out are: Corvette valve covers are notched in the back on one cover, this worked good on drivers side.
Exhaust manifolds are off a 77 454 pickup. Just had to grind a "nub" off the manifold to fit.
Stock hei fit to the firewall with a little caressing of the firewall.
Hope this helps. Mine is a 1/2 ton with no body lift.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 01-05-2005, 10:23 AM   #14
That ain`t bad.At first it was sounding like alot of trouble:moving cross-members,oil pan clearance,body-lift(yuk!).You have to dent the firewall for HEI on a small block,too.
Old 01-05-2005, 02:13 PM   #15
mrein3
mrein3's Avatar
The HEI in my small block clears my firewall fine. This last time it was in the engine when I installed it. However I originally installed it in a 350 in the factory location while the engine was in the truck. I pulled and installed the HEI distributor a couple of times.
You do have to remove the cap first. And it is a tight squeeze. But it makes it.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
