Old 06-25-2001, 08:21 PM   #1
johnymac
Question replacing rear coil springs.
I figured I would ask again before I start my next little project. Replacing the rear coil springs on my 67 c10 2 wheel drive.
The truck currently has some stock springs that seem to have been heated, they now seem to be compressed, no spring at all to them now. I think they have dropped the rear over 6 inches.
Anyway, I want to replace. I have never done springs before, so am looking for any advice that I can get. Any would sure be appreciated.
By the way, the springs I am replacing with are 5" drop coils.
Thanks much!
johnymac is offline   Reply With Quote
Old 06-25-2001, 09:21 PM   #2
cdwhzk
Post
It's real easy to do just jack it up so the sprins are extended with the wheels barely on the ground with jackstands under the frame rails take the bolts out slip the springs out and put in the new ones
71c10 350/350 air ps pb 320hp crate 2004R tranny from FB performance 410moroso posi completely rustfree body
27T coupe chopper 6.5 inches channeled total height 41inches powered by bigblock Edsel punched out to 490ci topped with 6stromberg97's built back in 67
Whizzer motorbikes 6or7
71C5 Blazer 350/350 needs rust repair but runs new
74Pinto stationwagon daily driver
cdwhzk is offline   Reply With Quote
Old 06-29-2001, 06:40 PM   #3
LeRoy
Registered truck nut
LeRoy's Avatar
Post
I'd have to disagree with it being easy. I just did the rear of 66 and my 69. The 69 had been heated up to the point of not being able to get a wrench in. It was easier to just cut the spring out and then unbolt them. The 66 had severely rusted bolts and I ended up just snapping them off. Did you order new lower retaining cups. Most likely you'll need them
MOUNT VERNON, WASH. STATE
GOT MY BASES COVERED
-Big and bad 70 CST Blazer
-71 K5 Blazer, 350, 4spd
-Work in progress 72 SWB
-72 Cheyenne, lwb, 1/2 ton, 4x4, V8, 4spd.
-71, 3/4 ton, 402/400, Custom Camper
-69, 2wd, ST6, auto, ghetto lowered, 3/4 ton, LWB, "BOMBER"
-69 Chev., lwb, utility trailer, 35" tires,
-88 1ton BB workhorse
Add or Delete Daily
Need a part? Just PM me
LeRoy is offline   Reply With Quote
Old 07-06-2001, 08:13 PM   #4
stretch
Post
When I replaced mine, I screwed around with a wrench and cheater bar for a while. After a couple hours of sweat and cussing, I gave up and got out the ol' gas axe. I cut the bolts with the torch, popped out the springs, and had the new ones back in in 30 minutes. And LeRoy is right - get new retaining cups...
'71 Custom 10 in progress
350/TH350/3.73
Holley 650 Dbl. Pump, Headers, HEI
'84 K-10 Silverado Blazer daily driver
'71 Custom 10
350/TH350/3.73
'76 K10
350/TH350/205/12-bolt(R)/Dana44(F)
Primer Gray!
'01 Grand Prix GTP - my 260 HP gas sipper!
Victory Red
stretch is offline   Reply With Quote
Old 07-07-2001, 12:02 AM   #5
Fast68Chevy
Fast68Chevy's Avatar
Post
yeah good luck having the bolts come loose with tools, lol
Hot wrench is the only way if the truck is driven in weather.
Fast68Chevy is offline   Reply With Quote
