Old 01-11-2005, 09:48 PM   #1
cochino12
It followed me home?
cochino12's Avatar
help with rear of my K5 please
I currently have a 4" blocks(tapered) and a 10 bolt and am ready to swap out to a 14sf now. The P.O. of the 14sf had the spring perches reangled because he didnt want to use shims. What is the 1)best 2)cheapest way of getting the 14sf under my Blazer and keeping drveline angles where they should be.
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 01-11-2005, 09:52 PM   #2
drink2mny
drink2mny's Avatar
If you keep the blocks then you might just move the perches..
If you don't move the perches then look for 4in lift springs.
Or a shackle reverse
Support The Board
drink2mny is offline   Reply With Quote
Old 01-12-2005, 12:30 PM   #3
Prerunner1982
Prerunner1982's Avatar
go with a shackle flip.. keeps stock springs for better right and controls axle wrap better than 4" blocks...
Prerunner1982 is offline   Reply With Quote
Old 01-12-2005, 12:30 PM   #4
cochino12
cochino12's Avatar
That was the original plan but witht the perche angle being changed wont that set the pinion way off?
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 01-12-2005, 12:34 PM   #5
Prerunner1982
yeah, any lift is probably going to change the pinion angle.... or no? could just shim the axle back to where it should be...
Old 01-12-2005, 01:49 PM   #6
CHEVYJEFF
CHEVYJEFF's Avatar
I would bolt it up and check the pinion angle. you might not need to do anything. you could always reverse the blocks to have the taper face the other direction and see what you get. Or get you a shackel flip and be done.
http://members.cardomain.com/chevyjeff
57 2 DOOR HDTP
82 CORVETTE
90 V10 BLAZER
97 REGAL LSR 2100 (BOAT)
CHEVYJEFF is offline   Reply With Quote
Old 01-13-2005, 01:20 AM   #7
cochino12
cochino12's Avatar
HMM when I accidently reversed the block on my 2wd flip kit the drive shaft was too short, would it be the same for the lift? What if i shimmed it?
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 01-13-2005, 01:39 AM   #8
79Silv4x4
Workaholic
79Silv4x4's Avatar
Just get some shims to correct it and you should have no driveline problems. You can also lower the transfer case 1 inch to help with pinion angle nad vibration. If I were doing it on a vehicle I was keeping I would have the spring perches relocated, ditch the blocks and do a shackle flip or go with 4 inch springs. Might get better info at CK5 as folks there have already done everything you can possibly do to a Blazer.
79Silv4x4 is offline   Reply With Quote
Old 01-13-2005, 02:26 AM   #9
Destructo
I would be concerned about putting shims in there with blocks already, could cause issues, atleast thats what I think, I refuse to use anything bigger than a 2.5" block myself anyway.
But springs would be my first choice, with a set of springs and no shims it would be right.
1985 Scottsdale Shortbed 4x4
Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch.
2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle.
Destructo is offline   Reply With Quote
