Old 12-30-2001, 06:13 PM   #1
Montecarlo1986ls
Post STEERING BOX MASTER CYLINDER
Can I take the steering box from a 1987 camaro and master cylinder from a 87 camaro and stick it in my 1970 gmc pickup?
MOnteCarlo
Montecarlo1986ls is offline   Reply With Quote
Old 12-30-2001, 07:18 PM   #2
slam33
slam33's Avatar
Post
No
71 basic C-10 350. The only option is the rust.No nothing on it, but thats all about to change. <A HREF="http://www.geocities.com/stevemau/slam33page.html?1004806705410
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
</A>
slam33 is offline   Reply With Quote
Old 12-30-2001, 07:21 PM   #3
slam33
slam33's Avatar
Post
The mount for the box is all wrong and the pitman arm shaft is too small. The brake master is too small bore size and it's for a disc/drum combo and you have drum/drum
</A>
</A>
Old 12-30-2001, 10:19 PM   #4
Montecarlo1986ls
Post
what cars can i take the power steering and master cylinder out to make my manual steering 1970 gmc pickup to power steering?
MOnteCarlo
Old 12-30-2001, 10:32 PM   #5
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Post
cars? no cars.. but can take use the box off of any 68-80 chevy pickup 10-30 series
My Truck pictures
www.xframeimpala.com
68 4x4 short fleetside 327 CH465 edelbrock intake and carb MSD distributor its the "SHAGROLET"
56 big window short stepside 235 dual 1 brls
64ImpalaSS 327
70 C10 LWB fleetside custom/10 350/TH350
IM me on aol SN= SHAGROLET
68SWB4x4 is offline   Reply With Quote
Old 12-31-2001, 01:01 AM   #6
Fast68Chevy
Fast68Chevy's Avatar
Post
the reason why car boxes wont work is because if you look under the car and look under the turck, the cars boxes are mounted inside the frame rails and are totally different casting, and the truck boxes mount outside of the frame rail. VERY few parts in some rare cases will work on trucks,only some engine/tranny items and mostly small electrical items.
No suspension/steering or axle/frame items will swap.
Cars are cars and trucks are trucks, nothing alike.
good luck.,
p/s pump and brackets and pullies can get complicated in short order, it all depends on if the engine you have is setup with the original driver side mounted alternator and short water pump and ram horn manifolds(V8 engines)
A 68 C-10 panel and a 68 dually C-30 dump truck and a couple 71/72 chassis projects.
http://messenger.msn.com
[This message has been edited by Fast68Chevy (edited 12-31-2001).]
Fast68Chevy is offline   Reply With Quote
