Old 01-12-2005, 11:51 PM   #1
Goffer
Goffer's Avatar
Question Wiper Arm?
How do you get the dang wiper arm off? I've got a nice gash taken out of my thumb due to today's failed attempt. The spring in my driverside arm broke so it flaps a little above 45mph. Gonna get some new ones, cuz they look like the spings had been jerry rigged before.
'71 C10 swb 350sb/700r4
Goffer is offline   Reply With Quote
Old 01-13-2005, 01:39 AM   #2
powell72
powell72's Avatar
there is a small silver clip that you pry away from the splines with a small screw driver while you pry up on the arm between it and the cowl. if you truck is painted, good luck, don't scratch.
powell72 is offline   Reply With Quote
Old 01-13-2005, 08:10 AM   #3
4x4Poet
Good warning, Powell72. On Tuesday, I pulled the wiper arms off my K10. Scratched the cowl all to heck. But I'm painting it anyway. Goffer, wrap a thick rag around the wiper arm shaft to stave off scratches. Three hands helps. One to work the little screwdriver and two to work the arm off the splines.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 01-13-2005, 08:21 AM   #4
68C15
blood type; Retumbo
68C15's Avatar
Snap On tool # AS92 (IIRC). cost about $6. it is designed for the task & works great.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 01-13-2005, 09:55 AM   #5
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Click here http://www.mytoolstore.com/kd/kdbody01.html and scroll down to the bottom of the page to see what a wiper arm removal tool looks like. They do indeed work great!
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 01-13-2005, 05:37 PM   #6
Goffer
Goffer's Avatar
thanks for the help
Old 01-13-2005, 11:25 PM   #7
68C15
blood type; Retumbo
68C15's Avatar
the problem with those is that they have a tendancy to damage your finish as it pushes against the body.
I appologize for having the tool # wrong. it is actually tool # A192
Old 01-13-2005, 11:32 PM   #8
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Hmmm, mine has a padded back (rubber or cork, can't recall). I've only used it a few times, no problems yet.
- Mike -
RIP El Jay
Old 01-13-2005, 08:33 AM   #9
ACES
Life is a gamble
ACES's Avatar
I force that little silver clip out with a small screwdriver first.
Then I wrap the base of mine with a rag, Next I grab it with a pair of pliars. Then Yank as hard as I can. I usually get it on the third try.
Don't try to pry it up with a screwdriver while using your cowl for leverage. You are asking to screw up your cowl that way
1970 Orange CST C-10 w/350, posi, Longbed
The torpid artist seeks inspiration at any cost, by virtue or by vice, by friend or by fiend, by prayer or by wine.
-- Ralph Waldo Emerson
ACES is offline   Reply With Quote
Old 01-13-2005, 08:37 AM   #10
vtblazer
vtblazer's Avatar
The silver tab has been mentioned, do that.
From there I use a chunk of old rubber bed floor matt I kept & cut into a square, lay it on the cowl to prevent any scrathing and use a small pry bar under the wiper arm.
Work the arm and it will come up pretty easily.
Good luck.
vtblazer is offline   Reply With Quote
