Old 02-17-2002, 11:13 PM   #1
busta9876
Talking disc conversion on '67 swb
i've seen where people change the whole front cross member, like 7 bolts on each side, and go over that way, but can i just change my ball joints and steering conponents and use the spindals from say a 76? the ball joints are the same except for the taper that goes into the spindal. same on tierod ends. i guess my main question is do i have to change the whole crossmember?
1997 C3500 5.9L Cummins Conversion
1989 Caprice Classic 5.3L Turbo 4L80E
1967 Chevy C10 6.6L Duramax Conversion In Progress
http://www.lt1swap.com
busta9876 is offline   Reply With Quote
Old 02-18-2002, 04:44 PM   #2
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Post
no you can use ball joints spindles tie rod ends and www.classicperform sells a tie rod adjuster sleeve that makes it so you can use the orignal centerlink
My Truck pictures
www.xframeimpala.com
68 4x4 short fleetside 327 CH465 edelbrock intake and carb MSD distributor its the "SHAGROLET"
56 big window short stepside 235 dual 1 brls
64ImpalaSS 327
70 C10 LWB fleetside custom/10 350/TH350
IM me on aol SN= SHAGROLET
68SWB4x4 is offline   Reply With Quote
Old 02-18-2002, 06:08 PM   #3
Brad
Out of the carpool lane.
Brad's Avatar
Post
If you've got a donor truck already in mind...I swapped everything out from a 77, except the crossmember. It fits straight-up, and easier to remember when visiting the parts store. The only thing you'll use are the smaller u-bolts from your old setup.
WOU in Monmouth, Or
68 Camaro,250(No,I'm not putting in a 350!)
67,LWB,250(Again, I'm not putting in a 350!)
a work in progress
"Praise The Lowered"
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 02-18-2002, 07:31 PM   #4
busta9876
Post
i started working on the conversion today, i'm using a '76 for a doner, and i pulled both spindals, centerlink, and stearing box and pitman arm. i went ahead and purchased all new inner and outter tierod ends, adjusting sleeves, and upper and lower ball joints. the part number on the idler arm is same on 67 and 76 and i'm replacing the stearing box cause it has less play then my '67 box. check out http://www.fatmanfab.com/ they do a lot of tublar a-arms, and kits for lowering ect. not too steep on price either.
another question? does break line length to the front brakes matter? or can i relocate the stock position of the break praportiating valve (long word can't spell that one lol)? i assume the only thing that would matter would be brake line diameter.
anyways, thanks for the help! keep on truckin'
Old 02-19-2002, 06:57 PM   #5
CDN_GS455
Post
Hey Busta,
Use the master and prop. valve off the donor or find a power booster set up from a '71 or '72. ( I used a '72 3/4 ton booster/master/prop. valve) Use the brake hoses off the donor and relocate the lines from behind the crossmember to the front. You will also need the brass T from a '71 or '72 as the line sizes and fittins are different. The rear brake line fitting will also have the wrong fitting on it.
Feel free to e-mail me or post any Q's here. Good luck.
Brian
'68 Shortbox Stepside -- 250 cu.in. 4 speed, disc swap up front
'00 Grand Prix GTP Sedan
I AM CANADIAN!!! Go Oilers!
CDN_GS455 is offline   Reply With Quote
