Old 04-06-2002, 04:36 PM   #1
OneFine99
Post Solid Axle Swap for a IFS Truck?
Does anyone know about swapping a solid-axle onto a IFS truck? What all is entailed? could I just buy the front axle/steering set up off of a older/wrecked solid axle truck, and use that? Anyone that could lead me in the right direction, would be GREATLY appreciated. Thanks In Advance.
Jason
****Vanessa****
1999 Chevrolet Z-71 LS Ex. Cab
Summit White/Pewter
3" Performance Accessories Body lift
35x12.50 BFG's on 15x10 AR "Baja" series wheels
Stull Billet Grille
APC clear sidemarkers
True Dual Exhaust with Flowmaster 40 series mufflers (cats removed)
Port/Polished MAF
3.73's
Ported TB
Throttle Body Spacer
Limo Tint all the way around, 5% eyebrow across the windhield
JLAudio,PPI,Pioneer,Fultron stereo
OneFine99 is offline   Reply With Quote
Old 04-07-2002, 04:52 AM   #2
3truckcanuck
Post
What is the straight axle coming out of and what IFS truck are you planning on putting it into. It is not often I hear someone going this way. Usually it is going from a straight axle to IFS. I used to use a 67-72 Chevy van front axle when building street rods and it was all fabricating the needed parts and altering axle and steering assembly. If you are serious about going this way, let me know what you are using and I will try and give you a few things to think about before you get started.
3truckcanuck is offline   Reply With Quote
Old 04-07-2002, 01:03 PM   #3
OneFine99
Post
I'm was curious about swapping a solid-axle onto a '99 Z-71. (old c/k body style)This way I could go a LOT taller, for cheaper. Albeit, by the time everything got swapped and wahtnot, it mihgt be just as expensive. I don't know which axles would work, or what parts I would need..I was kinda looking for ANY info I could get, or if there was any websites out about this kinda thing.
****Vanessa****
Summit White/Pewter
Stull Billet Grille
Port/Polished MAF
3.73's
Ported TB
Old 04-07-2002, 03:29 PM   #4
3truckcanuck
Post
Z-71, oh, O.K. You are talking about four wheel drive front ends. Those I haven't touched. I thought you meant the old straight axle two wheel drive front end. Couldn't figure why you'd wanna do that.
Old 04-07-2002, 09:05 PM   #5
OneFine99
Post
...it's alriht.
****Vanessa****
Summit White/Pewter
Stull Billet Grille
Port/Polished MAF
3.73's
TB
****Vanessa****
Summit White/Pewter
Stull Billet Grille
Port/Polished MAF
3.73's
Ported TB
Old 04-08-2002, 02:46 AM   #6
lost wages
lost wages's Avatar
Post
i helped swap a solid axle under a friends ford, wasnt to bad. there is a couple places that make all the brackets you need for the swap, look in a 4x4 mag.
68 swb fleet soon to be bagged and big block powered
68 lwb fleet in primer
35 chevy truck
97 dodge on 35 boggers
3 out of 4 aint bad!
Jefferson city, MO
lost wages is offline   Reply With Quote
Old 04-10-2002, 02:52 AM   #7
herauf
herauf's Avatar
Post
www.offroadunlimited.com
ryan.
1987 k5 4x4...FOR SALE!!! (email for details)
will eventually be replaced by a 70-72 4x4 k5
herauf is offline   Reply With Quote
