Old 01-16-2005, 10:48 PM   #1
5150
C10 Club Tennessee
5150's Avatar
Width of a stepside?
What is the width of a stepside 70 model? I'm going to be pulling mine home with my father-in-laws trailer, but I wanted to make sure it will fit.
thanks,
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 01-16-2005, 11:07 PM   #2
5150
C10 Club Tennessee
5150's Avatar
ttt
Bryan
www.gmtruckshow.com
Old 01-16-2005, 11:40 PM   #3
patrick66
crazy about dem trucks!
patrick66's Avatar
Thumbs up
If you're using a UTILITY trailer, the majority of those are 76" between the fenderwells. you can get the truck on the trailer, but you'll have to crawl out the door window to get out (you'll not be able to open the door, unless it's a 4x4). A true CAR HAULER (yes, there's a difference!) is 82"-83" between the fenders, allowing you to put even a one-ton on it without a problem. You can put anything up to a crew-cab longbed on an 18' trailer, but you will have overhang!!! On a 16', don't go longer than an extended-cab shortbed or a club-cab longbed.
Utility trailers have the rails above the deck, normally 12"-15" high. A true car hauler has a flat deck and NO rails above the deck surface. I do NOT recommend hauling a full-size PU on a trailer 14' or less in length, as you'll likely run into fishtailling problems the faster you go.
I sold new and used utilities and car haulers for six years, so I have experience in this arena.
Your stepside should fit, whether it's on a utility or a car hauler. Just use caution and some common sense, and you'll be good to go. TIE THE TRUCK DOWN securely around the rear axle and around the engine crossmember, use chains with cinchers or tie-down straps with the axle-strap ends. Rope is a no-no! Strap it, chain it, or both!
patrick66 - '67 C-10
patrick66 is offline   Reply With Quote
Old 01-16-2005, 11:42 PM   #4
5150
C10 Club Tennessee
5150's Avatar
My father-in-law says it's 75 and a half inches, so 76 sounds about right.
Bryan
www.gmtruckshow.com
Old 01-17-2005, 12:07 AM   #5
me3
hart
my uncle drives truck flatbed and he says he cant go through california without having some rope tiedown the idoit think rope is better than chain. rope may be stronger but its imposible to get it tight like chains and a come along.
me3 is offline   Reply With Quote
