Old 01-19-2005, 02:28 PM   #1
TC70C10
TC70C10's Avatar
Easiest way to remove upper rear shock bolt
I just got a sweet deal on a 85 K5 one owner on New Years day. I've been going through it and replacing parts/maintenance that has been neglected.
I'm working on the rear shocks and the upper mounting stud has what looks like a rivet instead of a nut. I grinded it off last night and got the washer off. What's the easiest way to remove that mounting stud. The nut is inside the frame overtop of the gas tank. I'm thinking about taking the sawzall to it an be done.
It looks like I can get a breaker bar on a 3/4 in open end and try to break the stud loose from the shock side.
1981 K5 Blazer 305, 4spd, 4x4, 4" Lift, custom bumpers, Warn 9.5 Ti Winch
1995 T10 Blazer 4.3L 4x4 (Son's)
2004 GMC Envoy 4.2L 2WD
2005 GMC Sierra Crew Cab Z71 4x4 5.3L
240 Fun Finder Travel Trailer
Harvest, AL 35749
TC70C10 is offline   Reply With Quote
Old 01-19-2005, 05:57 PM   #2
dons454s
dons454s's Avatar
If it is like mine you need to just beat it out like a wheel stud then replace it with a hardened bolt and nut.
dons454s is offline   Reply With Quote
Old 01-20-2005, 02:34 PM   #3
TC70C10
TC70C10's Avatar
Hey Altoona
I'm originally from Hermitage.
Well after trying several different angles, breaker bars, extensions and several doses of rust eater, I took out the sawzall, the grinder, drill and finished it off with a cold chisel. What a PITA.
Passenger side was a piece of cake. Thank God.
Harvest, AL 35749
Old 01-20-2005, 04:48 PM   #4
dons454s
dons454s's Avatar
Glad you got it.. Before I got the hot wrench. I had one that I had to use the grinder on then peen out with the chisel and hammer. And I agree what a pita for sure.
Old 01-21-2005, 10:57 AM   #5
KShortell
KShortell's Avatar
Yup, that's what I had to do. When I upgraded to the Edelbrock Performer IAS shocks which I love, I had to install new upper shock mounts front and rear. Definitely a pain...
Semper Paratus
KShortell is offline   Reply With Quote
