![]() Join Date: Apr 2000
dash lights won`t come on.
i just bougt an 85 c-10 and i don`t have any dash lights, i checked the fuses,any suggetions??
thanks jamie
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
![]() Join Date: Apr 2004
did you check the dimmer?
7000 #'s of american IRON
dimmer or something in the wiring. whip out your multi-meter.
Had the same problem, pulled out an replaced light switch, problem solved.
if the fuel gage quites workin to when you turn the head lights on. ihad this problem it is in the gage cluster and u will have to find a different cluster to put in.
Professional Grade
If the fuel gauge quits working when you turn your headlights on (and your signal lights in the dash come on, along with the high beam indicator being reversed) then your ground is bad. Check the ground at attaches to the bolt on the emergency brake.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
